PS2 and Gun question!
Method
PostPosted: 18:33 - 11 Nov 2006    Post subject: PS2 and Gun question! Reply with quote
Ok so ive got myself a USB gun thingy for the PS2 and i have the original GCON 45 thingy from my PS1.
Both guns work perfectly on the PS2 with the games that i have, but ive just got time crisis 2 and some other game that allows 2 players...
My question is, how on earth do i wire it all up so that both guns work together? Where do i put the video in leads and that so that both are working? And how do i get them both to be recognised etc...
Im a bit of a noob at these things Smile
CHeers Thumbs Up
CBT Aug '03 ... Gilera GSM 50 ... Honda NSR 125 Aug '04 ...
Full Test Dec 04... Suzuki GS500 Jan 05... Suzuki SV650 Mar 07... Gixxer 6 K5 May 08... Oh and my 'Rado Wink
My Bikepics.com - No Brakes, No Gears... No Fear.
WildGoose
White Van Man
PostPosted: 20:40 - 11 Nov 2006    Post subject: Reply with quote
god knows how you set that lot up, i've got two G-con 2's and they are difficult enough, however, the video in leads have T pieces on them rather than standard connections, so you can connect them in parallel, because it was thought into the design process
there is probly a way with your set up, but it might be a headache, sorry i cant be more help
why dont you just pick up a couple of G-con 2's, they are far superior to the 45 and anything else i've used, and the action/hide button is actually in a place where you can use it without having both hands on the gun Thumbs Up
Villers
Im a bit confuse myself. I had both the original g-con and the second blue one. When I wanted to use both guns simultaneously (like for double gun mode Cool ) you had to put both yellow video leads into the PS2's AV cable. I cant remember if one of these had a double socket. Other than that it was a case of plugging them both into the machine and away you go. That is assuming that your other gun is compatible with Time Crisis and vice versa.
Method
PostPosted: 13:32 - 12 Nov 2006    Post subject: Reply with quote
Both guns work and that, its basically how i hook up the two yellow AV leads to go into the tele.
I figured that it would have to be in parallel but i can only see how to hook them up in series... They have the T Peice connections and i just put one into the PS2 lead out like you should with one gun, and just stuck the second one on the other side of that, but thats not parralel so they didnt work.
How did you put yours in goose?
WildGoose
White Van Man
PostPosted: 13:39 - 12 Nov 2006    Post subject: Reply with quote
i'll dig out the manual later tonight cos i cant remember exactly, and hopefully i'll try and get you an answer Thumbs Up
Method
PostPosted: 15:29 - 12 Nov 2006    Post subject: Reply with quote
Cheers dude!
The last post was made 19 years, 282 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.73 - MySQL Queries: 13 - Page Size: 49.89 Kb
