Oil leak?
Syx
PostPosted: 17:03 - 13 Nov 2006    Post subject: Oil leak? Reply with quote
I've recently noticed spots of oil on my garage floor under the bike, and obviously I'm a little concerned as it's only recently been happening. Would anyone be able to suggest what might be causing this to happen?
Checking the dipstick reveals that the oil level is lower than what I can recall the last time I checked (which wasn't too long ago, mind). The bike had a full service in August.
hmmmnz
PostPosted: 18:38 - 13 Nov 2006    Post subject: Reply with quote
best thing to do is find out where the oil is coming from first off, my stab in the dark is that its coming from the gear change oil seal,
thats a complete stab in the dark with no info at all Very Happy
im sure we could all guess untill the cows come home, you have to give us some more info, for us to be any real use Very Happy
the humans are dead
I kick arse for the lord
Syx
PostPosted: 18:39 - 13 Nov 2006    Post subject: Reply with quote
Right well I'll see if I can find out tomorrow - I'm not too mechanically minded regarding the bike though so I'm not certain I'll be able to locate it at all!
Quote Me Happy
PostPosted: 18:40 - 13 Nov 2006    Post subject: Reply with quote
One thing you could do to make it easier to spot is to give the engine a thorough clean so when new oil appears you can see it Thumbs Up
Walloper
PostPosted: 19:48 - 13 Nov 2006    Post subject: Reply with quote
Drain Plug Oil Seal?
Oh look.
I can see a cow coming...
Wash and Observe as the man says. Laughing
Syx
PostPosted: 13:13 - 14 Nov 2006    Post subject: Reply with quote
Right I've whipped of all the relevant panels and had a look - seems like it might be coming from the region of the oil filter.
I've cleaned the entire area as much as possible, so now I get to wait and see!
Syx
PostPosted: 15:42 - 14 Nov 2006    Post subject: Reply with quote
Update:
With the bike having sat for a while I couldn't find any trace of oil leakage. So I decided to start it up - and within moments I could detect (using a highly advanced piece of kitchen towel) oil leaking from beind the front sprocket.
Any ideas what this might be? Is it worth taking the sprocket off and having a go at fixing it myself, or should I just take it to the dealer now I know the location of the leak?
Davo
Davo To The Rescue!
PostPosted: 16:34 - 14 Nov 2006    Post subject: Reply with quote
If I were you I'd take the front sprocket cover off and have a look.
Need to see if you can see any damage to the engine casing around that area if there is it could be expensive.
Whilst back there clear off any of the crud that's around the front sprocket there and check the security of the lock washer & front sprocket nut (as on the 99 R6's they seem to come loose).
What year is the bike?
Syx
PostPosted: 16:51 - 14 Nov 2006    Post subject: Reply with quote
It's an 03, with about 8k miles on it.
I've got the sprocket cover off already, which is how I could tell the leak was coming from behind the sprocket. The nut and lock washer seem pretty secure.
I can't see any damage to the engine casing at all, after cleaning the muck off it all seems okay, could a seal have possibly broken somewhere?
I am quite concerned about this as I wouldn't expect the bike to have such a problem at it's age, and even more so as the problem has occured quite suddenly.
Syx
PostPosted: 00:16 - 15 Nov 2006    Post subject: Reply with quote
I took the front sprocket off, and the oil is definitely leaking from the drive shaft - the seal must be damaged.
Any idea how this would happen?
And how tough is it going to be to fix? Am I best just taking it to my local Yammy garage?
Mark_petty
PostPosted: 13:37 - 15 Nov 2006    Post subject: Reply with quote
I wouldn't worry too much. I had a similar problem with my bike. Turned out to be leaking from the neutral switch. They originally thought it would be the seal for the sprocket, I was advised that if it was that it wouldn't cost hardly anything. Let us know how u get on Thumbs Up
[Rides: Suzuki GSF600sx]
[CBT: Passed] [Theory: Passed] [DAS: Passed]
Syx
PostPosted: 16:49 - 15 Nov 2006    Post subject: Reply with quote
Well I spoke to a few guys on the R6messagenet, and they've explained what could cause the problem. They've also told me how to solve it, and essentially I don't really have the techincal know-how to do it... so it's off to the garage!
I've had several quotes, all in the region of £400 Shocked Sad
I can't get anyone to look at it for at least a week though, so I'll post more when I know more.
Walloper
PostPosted: 21:00 - 15 Nov 2006    Post subject: Reply with quote
Phuque!!! Shocked Crying or Very sad
Get yourself technicaled soon.
Finglonga
PostPosted: 21:20 - 15 Nov 2006    Post subject: Reply with quote
I take it you need to split the box to get the seal in....Bummer. Thumbs Down
Andy Sez....
F.Y.Y.F.F.
The last post was made 19 years, 40 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 0.48 - MySQL Queries: 13 - Page Size: 81.3 Kb
