Why does my bike seem to run better when it's cold?
5v3d3b0
PostPosted: 23:11 - 13 Nov 2006    Post subject: Why does my bike seem to run better when it's cold? Reply with quote
When it's cold my bike just seems nippier...That I think is the opposite of the normal thing to happen...
mr.z
PostPosted: 23:14 - 13 Nov 2006    Post subject: Reply with quote
Cold air is denser than warm, so more oxygen, similar to the effect of nitrous which does what it does it has a higher concentration of oxygen than normal air..
(at least thats how i understand it)
Finglonga
PostPosted: 23:19 - 13 Nov 2006    Post subject: Reply with quote
Yep, and they also run better if the air is damp.
Andy Sez....
F.Y.Y.F.F.
5v3d3b0
PostPosted: 23:37 - 13 Nov 2006    Post subject: Reply with quote
Another question...Why does an engine actually need warming up before you hit full throttle? Doesn't quite make sense to me...Does it have to do with the expansion of the cylinder bore or something?
Davo
Davo To The Rescue!
PostPosted: 23:40 - 13 Nov 2006    Post subject: Reply with quote
My understanding was it's to allow the oil to properly protect the engine.
lilredmachine
PostPosted: 23:46 - 13 Nov 2006    Post subject: Reply with quote
If you punt the bike from cold, the piston will heat up much quicker than the surrounding block. The effect is exaggerated by the oil not being at optimal temperatureand causing increased friction.
Laymans terms, you'll seize the fucker.
befdelta7
PostPosted: 00:39 - 14 Nov 2006    Post subject: Reply with quote
my bike (listed below) seems to be a lot quicker on accelerating when cold (left over night), seems to have more of a pull for say first mile. but when warmed up just goes normal! same with my scooter when i fitted a malossi air filter would accelerate super quick for first mile or so when started up in the morning then would run normal after that untill next morning.
Dont do a wheelie in front of a traffic copper... it gets you 3pts and £220 fine.
Paddy Blake
PostPosted: 01:04 - 14 Nov 2006    Post subject: Reply with quote
Also the piston is oval shaped and becomes round when the engine is hot.
Paddy.
TheDonUK
PostPosted: 02:06 - 14 Nov 2006    Post subject: Reply with quote
Maybe its just your perception after waking up, then you get used to it?
Dom_
Points Mean Prizes
PostPosted: 11:56 - 14 Nov 2006    Post subject: Reply with quote
Nah, my rs50 was definately quicker in winter. My car also seems nippier when cold albeit a lot more jerky as well.
lilredmachine
PostPosted: 12:02 - 14 Nov 2006    Post subject: Reply with quote
well, as your motor warms up, so will the air around it. This air will be less dense/contain less oxygen per unit than cold air. Hence it will not burn as well as cold air.
It will be a tiny difference, but large enough to cause a large psycological one.
JonB
Afraid of Mileage
PostPosted: 12:27 - 14 Nov 2006    Post subject: Reply with quote
I found my 2 stroke 50 was more nippier in the cold than my 4 stroke 600.
mark83
PostPosted: 13:08 - 14 Nov 2006    Post subject: Reply with quote
Boys boys boys (and girls, if there are any Razz )
You're neglecting one thing: who cares how cold the air is and how nippy the engine is when your tyres are stone cold and more slippery than a soap bar in a gay prison. (Quite proud of that one actually!!!)
Kawasaki ER6n -> Honda CBR600RR -> Honda VTR 1000 -> Moto Guzzi Norge 1200
Buy my Mercedes 350 Sport AMG Evo
brooky
PostPosted: 13:35 - 14 Nov 2006    Post subject: Reply with quote
Im just having a guess here but perhaps this could be something to do with the mixture? Especially with your scooter and the filter this could affect the air/fuel mixture?
Suzuki GSX-R 750 K6.
Dom_
Points Mean Prizes
PostPosted: 13:57 - 14 Nov 2006    Post subject: Reply with quote
It will burn as well, just there is less of it to burn.
Tiny difference yes, but large enough for you to notice it.
colin1
Captain Safety
PostPosted: 14:32 - 14 Nov 2006    Post subject: Reply with quote
also has something to do with enthalpy. the bigger the difference between fuel and air in, and exhaust gases out, the more energy is released
some vehicles have intercoolers purely to cool down air to get this effect. cold air is denser, so more oxygen in a given volume of air, and also the enthalpy thing
mark83
PostPosted: 14:43 - 14 Nov 2006    Post subject: Reply with quote
Actually, it has nothing to do with oxygen and enthalpy.
In fact, its all to do with the fact that the bike is freezing its nuts off and wants nothing more for the rightful owner to jump on rag the tits off it! Laughing
TheDonUK
PostPosted: 15:21 - 14 Nov 2006    Post subject: Reply with quote
Smile, The engine on my bike is at the point where you must rag it from cold, there is no "idle" for a good while... Have to keep the revs up while freewheeling to a halt for the first few mins. But as someone else pointed out i like to let my tires get up to temp before i give it the beans.
befdelta7
PostPosted: 17:39 - 14 Nov 2006    Post subject: Reply with quote
na the mixture was correct, i re-jetted the carb to suit the filter (many hours and miles to get it spot on). im thinking (reading peoples opinions) it could be something to do with the denser air, on some cold mornings i dont even need to use the choke seems fine starting and warming up with out it. think its got something to do with the denser air, me thinks.
greatmoorred
PostPosted: 19:15 - 14 Nov 2006    Post subject: Reply with quote
Ive noticed this too, my bandit loves it when its cold. Tends to cut out a bit in the summer but never misses a beat when its chilly.
satellite
PostPosted: 19:26 - 14 Nov 2006    Post subject: Reply with quote
My dad told me that for every 1 degree you can reduce your engine temperature you get an effective gain of 5 BHP! Now this sounds mad, but he is quite good at that kind of thing and is currently fitting a water injection kit to his car Smile I don't know if it translates the same for a bike though? (I know a company does a stupidly expensive charge cooled kit for my car too)
09 Ninja & some four wheeled rotary goodness.
The last post was made 19 years, 282 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 0.41 - MySQL Queries: 13 - Page Size: 112.88 Kb
