oh god a barrel and piston help!!!!!!!
tanner
Guest
PostPosted: 09:28 - 29 Apr 2002    Post subject: oh god a barrel and piston help!!!!!!! Reply with quote
when fixing my exhaust onto my bike when i heard a crack the part where the exhaust fixes onto the bike was f*cked one of the studs had brocken off withe a bit of the material carnells have got my bike at the moment and reckon i need a new barrel and piston is this likely(how much do they cost?) is there nothing that can be done to fix it . i was thinking about getting a big bore kit were can they be bought from and what would i need to do to my bike to set it up for a big bore kit jetting bigger carb etc THANKS FOR YOUR REPLY Question
Dylan
PostPosted: 18:49 - 29 Apr 2002    Post subject: Reply with quote
The bolts are only meant to be tightned to 10 ib/feet which is nothing!!!! I didnt realise it was that low until i looked at the manual. It will probably just be the stud that has snaped. Only nout £3 to replace, unless it snapped of right next to the cylinder, dunno what theyed do then??? Probably drill it out or summin.
Dyl
PostPosted: 23:16 - 29 Apr 2002    Post subject: Reply with quote
If the stud has snapped off then it should be possible to drill it out and replace it with a new one. However, I would be tempted to take it to someone with the correct tools to do the job properly, and you may have to take the barrel off to get at it safely.
You may well be able to get away with drilling it out yourself without taking the barrel off, but get it wrong and you will wreck the thread
All this assumes the stud has sheared off, and not that the section of the barrel it screws to has cracked off
TANNER
Guest
PostPosted: 09:09 - 30 Apr 2002    Post subject: ITS WORSE Reply with quote
THE STUD SNAPPED OFF WITH A BIT OF THE FLANGE WHAT THE EXHAUST JOINS ONTO
PostPosted: 21:10 - 30 Apr 2002    Post subject: Reply with quote
In which case it is repairable, but not easily. A decent engineer can build the casting up with weld and drill and tap it (just had this done to a mudgaurd mount on a pair of forks). Find a decent small bike engineer (I use one in Stoke, but there is bound to be one close to you) and talk to them. They may be able to do it with the barrel in place, or they may want you just to take the barrel on its own to them
Mike
Guest
PostPosted: 03:15 - 01 May 2002    Post subject: simalar thing happenned Reply with quote
i snapped the bolt connecting to the 2 stroke pump, get a small (very small) screw driver tap it gently into the broken bolt anti clockwise until it starts taking shape then it should undo itself after a while (it takes a while o just be gentle and you will get there)
The last post was made 23 years, 352 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.05 Sec - Server Load: 0.99 - MySQL Queries: 13 - Page Size: 45.1 Kb
