Bulbs, both blown?
Mozzer
PostPosted: 19:39 - 15 Nov 2006    Post subject: Bulbs, both blown? Reply with quote
Okay, having troubles with my dipped beam... I've taken my bulbs out and gottten a multimeter...
Here is the response I got from it, same for both bulbs.
Both gone, or am I being a fool? I have no clue here, just making it up as I go along.
1st: June 6th 2006 - Nov 6th 2006: 2001 Aprilia RS125 |2nd: Nov 12th 2006 - Present: 1991 Honda CBR400RR
Jamie Stokes wrote: it now has a memory of 512mb and is super fast
Nb
PostPosted: 19:48 - 15 Nov 2006    Post subject: Reply with quote
Does happen sometimes. Does the coil filament at the end of the bulb look damaged? Have you got voltage from the headlamp connections to the bulb? If you rattle the bulb about can you hear anything? Most likely its just the bulbs.
Mozzer
PostPosted: 19:53 - 15 Nov 2006    Post subject: Reply with quote
One bulb i can phsyically see the break in one of the two filaments, and the other I can hear a rattle.
Fucking halfords with a million bulbs in and not one 60/35.
Timmeh
PostPosted: 19:57 - 15 Nov 2006    Post subject: Reply with quote
Are they correct rating? May sound a bit basic but it does happen.
alains
PostPosted: 20:00 - 15 Nov 2006    Post subject: Reply with quote
your bulbs seem to be H4 60/55W (60/35 do not exist to my acknowledge) , try halogen bulbs clear here
https://beedspeed.com/bulbs-gauges-counters-wiring-bulbs-c-83_175.html?osCsid=32e30bb4b47a6ebd32b4ed22cc4a9c3b
Mozzer
PostPosted: 20:17 - 15 Nov 2006    Post subject: Reply with quote
The picture was just a ranom picture I found on google... the bulbs I have say "12V60/35W Japan" on them.
Surely putting 60/55w bulbs in will blow something?
syl
PostPosted: 22:48 - 15 Nov 2006    Post subject: Reply with quote
Import bike, import bulbs, I guess. They might not exist over here. If the 60/55w ones fit, I'd use them. Otherwise you'll have to order a proper one from the net here or here.
Current bike: Kawasaki Z750S
Zimbo
PostPosted: 00:22 - 16 Nov 2006    Post subject: Reply with quote
Might be worth using your multimeter to check the charge output from the bike, make sure the regulator isn't faulty. Run the bike and rev it, if the voltage across the battery stays at 13 - 14 volts all is well, if it rises to say 16 volts when revved then you need to replace the reg / rec unit too. Multiple blown bulbs is often a sign of a faulty reg / rec.
The last post was made 19 years, 37 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.05 Sec - Server Load: 0.27 - MySQL Queries: 13 - Page Size: 58.5 Kb
