Gixer fan blowing fuses?
17-in-87
PostPosted: 14:15 - 27 Nov 2006    Post subject: Gixer fan blowing fuses? Reply with quote
I've got a K1 GSX-R600, overheated last week as I got to work - checked the fuses and the fan fuse had blown. Replaced the fuse, again today the bike has overheated on the way to work, the fuse to the fan has blown again. Without stripping the bike down in the carpark at work, are there any obvious things I should be checking?
K1 GSX-R 600 - blue n white of course....
Growing old is compulsory - growing up is optional...
Paddy Blake
PostPosted: 14:21 - 27 Nov 2006    Post subject: Reply with quote
Check it the fan turning ok as there maybe dirt stopping it and causeing
the fuse to blow.
Paddy.
17-in-87
PostPosted: 14:44 - 27 Nov 2006    Post subject: Reply with quote
the fuse to blow.
Paddy.
Checked the fan, seems to turn ok? I think the problem may stem from last week - part of the A3 was flooded last Monday and I had to ride through a puddle that came up to the footpegs, so when the fuse blew last week I thought water might have got into a connector somewhere?
finpos
PostPosted: 14:46 - 27 Nov 2006    Post subject: Reply with quote
Often, there is no demand for the fan at all for years on end, then one day it's asked to come on and it's seized solid, which blows the fuse.
If you're lucky, there will just be something jammed in the actual fan, but be prepared fr the motor itself to be stuck. If so, you may be able to dismantle the motor, clean it up and put it back together.
finpos.
PostPosted: 14:56 - 27 Nov 2006    Post subject: Reply with quote
I melted the fan blades on my 'busa turbo and blew the fuse because they fouled the fan shroud. Are you sure it can spin a full circle? Other than that try unplugging the fan from the connector and then jumping the wires in the fan switch (screwed into the radiator). This will tell you if you have a faulty fan or a short in the loom somewhere.
0ddball
PostPosted: 15:14 - 27 Nov 2006    Post subject: Reply with quote
It's possible (although modern wiring and connectors are usually very well waterproofed) that the water has rusted the pins in the connector increasing the resistance in the circuit, hence drawing more current and blowing the fuse.
finpos
PostPosted: 15:21 - 27 Nov 2006    Post subject: Reply with quote
No, that would just make the fan spin more slowly (if at all) Smile. The effect here is a stalled electric motor, which has a very low resistance and so allows a huge amount of current to flow. Because this is a very real danger, you usually find that electric motors are individually fused in cars and bikes. That way, when a stone gets jammed in your radiator fan, the whole bike doesn't die.
finpos.
The last post was made 19 years, 230 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 2.36 - MySQL Queries: 13 - Page Size: 52.82 Kb
