Miles vs power loss
Itchy
PostPosted: 14:34 - 27 Nov 2006    Post subject: Miles vs power loss Reply with quote
Its said usually by blokes down the pub , that petrol engines lose power the more miles you put on them,
while diesels get more bhp as you cram more and more miles on them.
is this true?
And is there a general guide as to how much (not withstanding rebuilds and rebores etc) BHp you lose per say 10,000 miles?.
Any thoughts?
Ta
PostPosted: 14:52 - 27 Nov 2006    Post subject: Reply with quote
If anything you gain BHP if the engine is properly serviced.
Running/bedding in is an amazing thing.
Only if the engine is unhealthy/hasn't been serviced will it make less power.
Or, I suppose if it was poorly designed.
I'd be very surprised if a new Blade engine made less power at 10k miles than at 0 miles.
However a 100,000 miler might be less powerful, but I'd imagine that being more through neglect than anything else. A freshly serviced and FSH 100,000 miler would be fairly fit I'd guess.
mark83
PostPosted: 16:09 - 27 Nov 2006    Post subject: Reply with quote
Its all to do with compression ratios.
Once you've worn the machine in, there's little more to be had in terms of power.
The engine will lose power because the compression ratio will fall.
BMW actually do compression ratio tests for their brand leaders, and I heard a 7 series loses only 3% after 10 yrs!
Might not be completely accurate though.....
Kawasaki ER6n -> Honda CBR600RR -> Honda VTR 1000 -> Moto Guzzi Norge 1200
Buy my Mercedes 350 Sport AMG Evo
PostPosted: 16:52 - 27 Nov 2006    Post subject: Reply with quote
It shouldn't lose much if any of it's power throughout it's serviceable life. Obviously piston rings wear and will need replacing but modern engines are generally very long lasting.
Dom_
Points Mean Prizes
PostPosted: 18:02 - 27 Nov 2006    Post subject: Reply with quote
I can't see a 100k miler with FSH making more bhp than a 5k miler tbh.
Wouldn't the lads at motogp be using old blade engines if thats the case. Laughing
MattHirst
PostPosted: 18:14 - 27 Nov 2006    Post subject: Reply with quote
hmmm no.....maybe old VFR 800 engines Very Happy Razz Dance!
0ddball
PostPosted: 18:15 - 27 Nov 2006    Post subject: Reply with quote
Race engines are a different story. They are built to reach their peak after a very short run in time and be knackered after a few hundred miles.
With a production engine there's no reason a 50,000 miler shouldn't make the same power as a 5,000 miler. The engine itself doesn't wear much if it's looked after properly. You might have problems with other components though at that milage. Injectors can varnish slightly, fuel pumps get tired, exhausts carbon up ect.
I don't think it will apply with bike engines as they are made for performance from the word go but some car engines will not make book power untill they have about 30,000 miles on them. So some can gain more power as the milage goes up, especially if you thrash them.
PostPosted: 18:23 - 27 Nov 2006    Post subject: Reply with quote
Well it does happen, but they don't gain hundreds of bhp - as would be required to compete in MotoGP.
I would be surprised if a mint well looked after 5k mile engine made more power than a mint 15k miler that has also been looked after.
colin1
Captain Safety
PostPosted: 18:31 - 27 Nov 2006    Post subject: Reply with quote
i know its true that cars lose bhp as they age in some cases (although not all)
top gear did a thing about it
i suspect its also true of bikes to some extent
PostPosted: 21:11 - 27 Nov 2006    Post subject: Reply with quote
Would expect a diesel to loose power just as much as a petrol engine.
Don't think bike engines are designed to last that long. Yes they will gain some power as they run in, but that isn't that long.
With miles the bores wear, the rings wear (both reducing compression), jets become worn / clogged, spark plugs get contaminated, valve clearances go out, cams wear (reducing the time valves are open slightly), etc.
Taking care of an engine will reduce this, but it is still wearing (mainly from cold starts).
The last post was made 19 years, 264 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.68 - MySQL Queries: 13 - Page Size: 68.79 Kb
