| dopplerhire |
 dopplerhire L Plate Warrior
| Big Pete |
 Big Pete Spanner Monkey
| Ichy |
 Ichy World Chat Champion
| stinkwheel |
| finpos |
 finpos World Chat Champion
 Posted: 02:11 - 22 Nov 2006 Post subject: |
It's often recommended to soak new friction plates in oil overnight before fitting them. Don't know the reason for this particular bit of folklore, but I've always done it. Even if you used the "wrong" oil, I doubt it will have had an effect so quickly.
Another possibility is that you broke your clutch basket because you didn't do all the bolts up evenly. That gives some very strange symptoms indeed
If you are taking the cover off for a quick look, it's sometimes possible to lean the bike over enough so that you don't have to drain and re-fill the oil. Don't try it on your best carpet, though.
finpos. |
| dopplerhire |
| finpos |
 Posted: 12:01 - 22 Nov 2006 Post subject: |
Sounds basically like your clutch isn't working. The 2-3-4-5 Upshift is pretty normal, you are doing clutchless shifts. Getting it in and out of 1st is a different prospect with a busted clutch.
There should be another aduster for the clutch at the end of the lever outside the crankcase. I'm a bit skeptical about there being an adjustment inside, but you never know. The haynes manual will have definitely mentioned it. As long as you've adjusted things at each end of the cable so that you have a mm or two of free play at the lever, than that's all you can do.
Frankly, for it to go from working fine to being broken that quickly, I'd expect something mechanical inside that cover to have gone wrong
finpos. |
| Big Pete |
| dopplerhire |
The last post was made 19 years, 230 days ago. Instead of replying here, would creating a new thread be more useful? |
