aprilia rs temp.
gingerhog
PostPosted: 18:28 - 27 Nov 2006    Post subject: aprilia rs temp. Reply with quote
hi.just changed my radiator on my rs125 as the other 1 had f#cked phins.what sort of temp should the aprilia be running at on tick over and a run?? also do you need to bleed it when the radiator has neen changed as i see there is a bleeding screw in a pipe.thanx
lanester
PostPosted: 21:27 - 27 Nov 2006    Post subject: Reply with quote
Yes you need to bleed the radiator system in order to get all of the air out. Otherwise this could cause an air blockage and would therefore in a worst case scenario result in no water pumping round your bike, normally it will just cause the engine to run hot (from my experience with friends cars)
The last post was made 19 years, 225 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 1.94 - MySQL Queries: 13 - Page Size: 31.09 Kb
