redoing hele-coils?
Kris
PostPosted: 16:21 - 27 Nov 2006    Post subject: redoing hele-coils? Reply with quote
When I attempted the valve clearances on the Blandit I fucked up two of the eight threads on top of the valve cover. Yea, yea I know - hamfisted fuckwittery at it's finest Razz
Anyhoo, my mechanic in his wisdom hele-coiled them when he re-did the valves although he later admitted they were 'dodgy' as he had to use a slightly incorrect size. He told me to order in new parts (these things are the half circle top piece which hold the camshafts down) but after speaking to the Suzuki dealer - guess what! Yea they don't sell 'em, come with the whole lot because of tolerances etc.
I guess my question is have you ever re-done hele-coils and if so, how hard is it? Reckon I should get the garage to have a go? They mentioned they could repair them but I'm wary of spending £££'s.
Any ideas?
www.prisonplanet.com
sickpup
Old Timer
PostPosted: 16:31 - 27 Nov 2006    Post subject: Reply with quote
So your mechanic has lunched your head basically as he couldn't be bothered to get hold of 7mm inserts for the cam cover bolts.
I may be able to repair them, I do a fair few of these but would need to look at them first off the bike.
At the worst depending on which cam holders it is I might have some but would then need to whole head and cams to get it line bored so they fit without wearing the cams out or seizing quick time.
I wouldn't use that mechanic ever again but I would consider sueing him for the cost of a new head. In the region of £1200 not including valves, guides, seals, building, head gasket and fitting.
Kris
PostPosted: 16:42 - 27 Nov 2006    Post subject: Reply with quote
Not 100% sure I understand your post dude, although thanks for the offer.
Are these things I can unbolt and take off and get done, then reattach to bike?
Very Happy
sickpup
Old Timer
PostPosted: 17:01 - 27 Nov 2006    Post subject: Reply with quote
On each cam there are 5 bits of Aluminium that hold the cams to the head. The top of 8 of these has an M7 thread to which the cam cover bolts onto. This is a design that is used to this day on most Suzuki sports bikes.
Your mechanic has over tightened the cam cover bolts, they only need about 10nm of torque. Then instead of fitting 7mm heli coils it sounds like he's just made a mess.
I would need to look at the caps to see exactly what he's done and how deep he's cut to decide if a repair back to 7mm is viable. If not I may be able to get some 8mm threaded caps from the states but again depends how much damage he's done to the caps.
Depends how much damage the twat has done.
sickpup
Old Timer
PostPosted: 17:12 - 27 Nov 2006    Post subject: Reply with quote
Heres the 8mm threaded 1mm oversize cam cover bolts.
clicky
PostPosted: 18:18 - 27 Nov 2006    Post subject: Reply with quote
Yeah my 'busa has 7mm caps too. I found out when I was going to mount my DTA using one of them for doing my cam timing Very Happy
Kris
PostPosted: 08:55 - 28 Nov 2006    Post subject: Reply with quote
Ahh, now I understand. Thumbs Up
You're not too far from me are you? Do you run a garage/workshop etc? 8mm would be okay if required, although I'd rather keep with the original bolts as you can understand.
I'd wager that most of the 8 threads are fucked Embarassed A combination of myself and previous owners I'm afraid. Oh and mickey-mouse alloys that take no effort to destroy Razz
So where do I go from here?
sickpup
Old Timer
PostPosted: 12:35 - 28 Nov 2006    Post subject: Reply with quote
You take off your rocker cover and post me the cam caps and I look at them or take them to an engineering workshop.
The 8mm bolts are weaker than the 7mm ones.
PostPosted: 12:44 - 28 Nov 2006    Post subject: Reply with quote
Another option you have is if you want to helicoil them out to 8mm then send me the M7 retaining bolts you have, I'll machine them out to accept M8 socket caps. Wouldn't take long and you'd have them back in 2 days.
sickpup
Old Timer
PostPosted: 13:21 - 28 Nov 2006    Post subject: Reply with quote
Thats a very elegant solution. The only downside is over tightening as you wouldn't feel the shoulders but up against each.
Still very elegant. Thumbs Up
Must get my lathe installed and repaired as well.
Kris
PostPosted: 13:23 - 28 Nov 2006    Post subject: Reply with quote
So how much would I be looking at in each case?
So are you a mechanic etc at the mo?
sickpup
Old Timer
PostPosted: 13:27 - 28 Nov 2006    Post subject: Reply with quote
At the moment I'm a courier but yes I've been accused of being a mechanic and I have all my equipment and gear at home.
Couple of quid if that each cam holder. Cover the cost of me getting hold of the 7mm inserts and the postage of course.
Kris
PostPosted: 13:36 - 28 Nov 2006    Post subject: Reply with quote
Well that's very generous of you!
Only problem is I use the bike daily for my commute (trains are so expensive). I'm struggling to think of a time when I could get them off and post them to you and not have to use the bike to get to work...
How long do you think it will take at worst case?
PostPosted: 13:37 - 28 Nov 2006    Post subject: Reply with quote
Timesert inserts are bigger than helicoils.
They also do a 'bigsert' which has oversized outer dimensions to repair inserts that have messed up.
Kits are very expensive to buy, however.
sickpup
Old Timer
PostPosted: 20:23 - 28 Nov 2006    Post subject: Reply with quote
Don't tell Hotdog.
A couple of days at most if its all 10 that need doing back to 7mm. If the mechanic has done something really stupid then who knows Confused
They come in different lengths but I've yet to see them in 7mm
On yes.
Kris
PostPosted: 12:31 - 28 Mar 2007    Post subject: Reply with quote
Righto
I've been a proper slack monkey with regards to getting these done. In other words I left it. Now the bike needs the clearances doing and the 'bodge' is barely holding Embarassed
So, first off are the offers still available that were posted here? Razz Cheeky I know but hey Thumbs Up
Secondly, any more ideas? I may be able to wheel the bike down to a garage who can hele-coil them 'in the frame'. Is this wise? I notice sickpup reckoned some bad things could happen if they move etc..
Anyhow, thanks for listening all.
sickpup
Old Timer
PostPosted: 22:46 - 28 Mar 2007    Post subject: Reply with quote
I cant do things quickly as I'm working more now but I can probably help.
Yes the cams will move in the head wearing the cams and the head excessively. Also there will be wear due to the oil gap being to large.
The last post was made 18 years, 278 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.13 Sec - Server Load: 0.55 - MySQL Queries: 13 - Page Size: 104.96 Kb
