wd40 on brakes
zenith10
PostPosted: 17:17 - 28 Nov 2006    Post subject: wd40 on brakes Reply with quote
hello today i was cleaning my motorbike and my dad started to spray everything with his wd40 like spray. he sprayed my disc brakes now my brakes are crap i can hardly brake anymore. what can i do to get rid of this and make my brakes good again?
CoronaBoner
PostPosted: 17:32 - 28 Nov 2006    Post subject: Reply with quote
Get some soapy water and give them a good soak and then dry them of with a rag or something.
Get your dad doing something useful, like cleaning the garage and not your bike!!
2004 RSV Factory
Cluck cluck chicken
Sparks!
Sir Tart-a-lot
PostPosted: 17:35 - 28 Nov 2006    Post subject: Reply with quote
The truth is mate, your dad is trying to kill you.
Does he resent you in any way? Are you next in line to the family business but he'd prefer your younger brother have the business? Laughing Wink
PostPosted: 17:41 - 28 Nov 2006    Post subject: Re: wd40 on brakes Reply with quote
Clean the discs using lots of strong degreaser and lots of elbow grease.
Take the pads out, clean those using brake cleaner and then sand the pads down a little bit as the tops of them will now have WD40 soaked into them.
And ermmm, you'd probably be best asking your dad if he can never touch your bike or do anything to it ever again. Laughing
mr.z
PostPosted: 17:48 - 28 Nov 2006    Post subject: Re: wd40 on brakes Reply with quote
Reminds me somebody here their dad cleaned their entire bike and but back to black on the tyres, first corner = floor.
I'd chuck the pads tbh, supposedly it'll burn off eventually but i'd change them anyways.. brake cleaner for the rest and never let him near it again Shocked
Dischord
PostPosted: 17:57 - 28 Nov 2006    Post subject: Reply with quote
I remember using GT85 on my discs, after doing it I went down a big hill and noticed my leg getting REALLY hot! the entire rear end of my bike was on fire Laughing Laughing If it was only a little it should wear off, when I used to clean my bike I always got something on the discs and it wears off after a mile or so!!
2012 KTM EXC 250
phk6
PostPosted: 18:04 - 28 Nov 2006    Post subject: Reply with quote
i dont even spray wd40 on the nuts and bolts on my bike unless im doing some work on it, i just spary bits of the fram which have small rust patchs on and tight spots were i cant clean to help my bike make it thru winter in one pice lol
Current .. 2008 BMW R 1200 GS Adventure ..
Before .. 2003 Yamaha Fazer 1000 .. 2004 Kawazaki Z1000 .. 2003 Suzuki Sv1000s .. 1999 zx6r Track Bike .. 1999 CB 500 Cup ..
/Phil
bandit-boy
PostPosted: 18:13 - 28 Nov 2006    Post subject: Reply with quote
i do some work in a pushbike shop. we get quite a lot of people spraying the WHOLE bike in the likes of GT85 to make it shiney Confused then complain the brakes are crap.
get some decent brake cleaner (basically just alcohol), get the pads out, then sand them down a bit of glass (or anything else really flat) while the're swiming in the brake cleaner (this prevents you from breathing in brake pad dust, and helps shift the oil). clean them of with a CLEAN rag, soak in brake cleaner again, and light them with a lighter. while the alcohol is burning off, and the pads are cooling down, clean the disks with plenty of brake cleaner and elbo grease as "ste" says.
it works on pushbikes, and it worked on my bandit when i got brake fluid all over the disks
I've just repeated what Ste said haven't i Question
loply
PostPosted: 20:34 - 28 Nov 2006    Post subject: Reply with quote
Just use the brakes for a while I'd suggest.
I've had WD40 contamination on my single front disc before, and after a few 70mph brake-dragging miles it was entirely fine.
Yamaha SZR660 Caution to the wind, the throttle pinned!
scoota bk
PostPosted: 20:38 - 28 Nov 2006    Post subject: Reply with quote
I know somebody, left his car parked out in the street, his dad was near it and got a bit of dirt or somehting on the paintwork, and thought it'd be a good idea to clean it off with WIRE WOOL!! Laughing Laughing I kid you not! Laughing
Paddy Blake
PostPosted: 21:08 - 28 Nov 2006    Post subject: Reply with quote
Wash the disc and clean the pads and spray WD40 on the peddles in your
dads car. Laughing
Pte1643
PostPosted: 21:11 - 28 Nov 2006    Post subject: Reply with quote
das car. Laughing
Even better...
Any of you guys ever heard of "HighStyle"? Twisted Evil
Cillit-BANG
PostPosted: 21:50 - 28 Nov 2006    Post subject: Reply with quote
Meths is also a good budget disk cleaner.
If you dare, and I mean take it very cautiously, a good ride in the wet will help. Build speeds up gradually until your confident the brakes are working again but keep to a speed you know you are still capable of stopping at.
PostPosted: 21:57 - 28 Nov 2006    Post subject: Reply with quote
"Disc brake cleaner" It does exactly what it says on the tin.
https://www.motohaus.com/acatalog/discbrakecleaner.GIF
BFG
PostPosted: 22:05 - 28 Nov 2006    Post subject: Re: wd40 on brakes Reply with quote
Yes do this as a minimum, best thing is to replace the pads. They're cheap. Disk cleaner will clean only the disk - TBH so will washing up liquid when it comes to WD40, but the pad surface will be ruined.
As to the just ride it / wash it / spray it (basically anything lazy or tightfisted) approach - This is Darwin award stuff. Don't do it.
Cue lots of "well I did it and it was OK" replies Wink
Cillit-BANG
PostPosted: 22:07 - 28 Nov 2006    Post subject: Reply with quote
I'm not a big fan of the stuff to be honest though. It's expensive, really is very potent unless used outdoors, and is never as good as you expect it to be.
Contact cleaners are usefull, but not for cleaning disks. A rag dipped in 1p's worth of meths works just as well I've always found.
BFG
PostPosted: 22:11 - 28 Nov 2006    Post subject: Reply with quote
Cillit-BANG wrote:
Cillit-BANG
That'd help with the disk. Wink
PostPosted: 22:19 - 28 Nov 2006    Post subject: Re: wd40 on brakes Reply with quote
Well I did it and it was ok.
Actually, I didn't even attempt to clean anything off on the several occasions I have got WD40/grease/fork oil/F365 on the brakes. Just repeatedly applied the brakes until they were proper bastard hot and it all burned off.
This should not be taken as a recommendation for what other people should do.
Ciar?n
PostPosted: 22:53 - 28 Nov 2006    Post subject: Reply with quote
As some1 else said, just find and empty road and keep jamming your brakes on until it cleans itself up.
Mine are fine and i've done it by accident twice now.
If you want your brakes to work REALLY well spray some pepsi on them...
_Will_
PostPosted: 23:34 - 28 Nov 2006    Post subject: Re: wd40 on brakes Reply with quote
mr.z wrote:
Reminds me somebody here their dad cleaned their entire bike and but back to black on the tyres.
Laughing Me dad did that when i was selling me moped, seat and tyres - slid around on the seat and polished tyes made quite a fun ride Laughing
Suffering Bike Withdrawal.
Timmeh
PostPosted: 23:59 - 28 Nov 2006    Post subject: Reply with quote
I found that araldite works really well for stopping your front wheel moving at all.
NSR Mick
PostPosted: 00:08 - 29 Nov 2006    Post subject: Reply with quote
muc-off, how about fuck-off. £5 odd for a can of re-labled carb cleaner, no thanks.
Ciar?n
PostPosted: 16:16 - 29 Nov 2006    Post subject: Reply with quote
Rofl.
I'll stick to what i know Smile
PostPosted: 20:33 - 29 Nov 2006    Post subject: Reply with quote
Meths is good shit for shifting it. That's meths the purple stuff, not crystal meth. Laughing
loply
PostPosted: 18:15 - 02 Dec 2006    Post subject: Reply with quote
I concur, there are far too many cleaning agents on the market that claim to be specific for one part, and they're usually all far too expensive.
The last post was made 19 years, 333 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.12 Sec - Server Load: 0.49 - MySQL Queries: 13 - Page Size: 132.08 Kb
