| veeeffarr |
 veeeffarr Super Spammer
 Posted: 23:02 - 28 Nov 2006 Post subject: GS500E - Slackening Fork Clamps (Headlight Brackets) |
Hi,
Trying to install some headlight brackets on my aftermarket-faired GS500E.
Hmmmz gave me the tip of just loosening the clamps and sliding the forks downwards to mount the brackets,
Are these the two clamp nuts I need to loosen before I slide the forks down? Is there anything else?
Cheers,
T
https://s66.photobucket.com/albums/h277/th0r0n/GS500Forks.jpg |
| finpos |
 finpos World Chat Champion
 Posted: 23:07 - 28 Nov 2006 Post subject: |
Yep - just watch you don't end up with the bike sat on it's engine
Edit - I'm not entirely sure what it is you're trying to do, but consider if you can simply remove the top yolk (loosen upper pinch bolts you have circled plus remove the big nut at the top of the steering pivot) without loosening the pinch bolts on the bottom yolk. It'll be a lot easier to handle.
finpos. |
| veeeffarr |
| finpos |
| Ichy |
 Ichy World Chat Champion
 Posted: 23:23 - 28 Nov 2006 Post subject: |
Agree with Finpos on this one. If you can get the top yolk off without too much trouble then go for it. Just not sure how the ignition switch and clocks are fitted
If your planning on sliding the foks down then you are still going to need to jack up the front of the bike and probably remove the calipers , wheel, and speedo drive cable, if fitted, to give you enough room. |
The last post was made 19 years, 208 days ago. Instead of replying here, would creating a new thread be more useful? |
