OK quick question
wilbur
PostPosted: 22:57 - 28 Nov 2006    Post subject: OK quick question Reply with quote
Went out tonight to buy beer on The GPZ500.
The suspension was eeeerm just wrong. it is picking up bumps it would normally sail over.
I had a few thoughts.
1) picked up a nail- no all looks OK as are the tyre pressures.
2) rear shock siezed - I suspect this may be the case. I hope not. stripping it is not trivial.
3) Hot spots on the chain-cannot see it, it has only done about 2K and I do look after it.
Any other things to look for ?
It is a bit difficult to explain how it feels.
I'll slap some WD40 on the monoshock in the morning.
It does get covered in crap and got drenched in some floods last week. Thank you to the complete wankers who drove in the opposite direction in your 4x4s though a one foot flood whilst I was poodling through in the opposie direction.
NSR Mick
PostPosted: 22:59 - 28 Nov 2006    Post subject: Reply with quote
The oil in your shock is cold therefore increasing the damping.
wilbur
PostPosted: 23:01 - 28 Nov 2006    Post subject: Reply with quote
Hmm could be. never noticed it before and I have been riding for 30 years.
But cheers.
NSR Mick
PostPosted: 23:11 - 28 Nov 2006    Post subject: Reply with quote
Embarassed Maybe not then, but after riding for 30 years you would know that your suspension linkages wont sieze in 1 day.
How long is it since you last rode it.
landy.s11a
PostPosted: 23:15 - 28 Nov 2006    Post subject: Reply with quote
sometimes when things are sh1tty..ie getting drenched by inconsiderate drivers, you tend to notice things you don't notice when you're enjoying the ride, when its raining and windy I notice rattles and noises on the beema all the time, when its dry I tend to ride the tits out of it and never notice the noises etc.
hope you get it sorted
Lee
"Speed:The thing about speed is that you can't catch the people who've attained it to ask them how they got so fast. You chase them day after day, until you find yourself getting closer. Then you catch them, and realize that your question has just been answered."
wilbur
PostPosted: 23:29 - 28 Nov 2006    Post subject: Reply with quote
Probably 24 hours.
It is very apparent (to me). I think I'll need to get the shock serviced or get a new one. The back BT45 still has 2k on it and the front is almost new.
It feels a bit like riding down a bumpy dirt track but on tarmac. So I think it is the shock......bugger but It IS ten years old. I will try lubing it first. I seem to remember they are a right pain in the arse to remove.
I have the Haynes within reach but cannot be arsed to look now. I'll just get annoyed.
It will fuck the handling though so I need to get it fixed quickly.
PostPosted: 00:35 - 29 Nov 2006    Post subject: Reply with quote
Spraying WD40 on the linkage will have next to no effect.
The GPZ linkage is a minor bugger to strip. Mainly because Kawasaki in their infinate wisdom designed it so that when the centre stand is down it blocks one of the linkage bolts. Need to use an axle stand under each of the frame rails. The bushes themselves run in plastic "bearings", which are a poor fit even when new.
The way you describe it sounds almost like the suspension has suddenly got firmer. Cannot think of anything that would cause that, except maybe a spring breaking.
PostPosted: 18:37 - 29 Nov 2006    Post subject: Reply with quote
Not unheard of to have problems with the shock, they get all the crap of the day sprayed up off the back wheel onto them). I sent an old one with a seized adjuster to a guy a couple of years ago when his one actually snapped the shaft.
As I recall (and it is a while since I did this), you can put it up on the stand then undo the dogbones and the top shock bolt (for which you will need a socket with a long extension, fiddly but do-able).
You should then be able to rotate the unitrak casting into a position that allows removal of the bottom bolt. The shock can then be manouvered out with a little muttered cursing and mildly skinned knuckles. You might need to take the back wheel out to allow you to drop the swingarm all the way to the ground, can't remember offhand.
When you put it back in, clart it with waxoil (or similar) and fix a section of car inner tube round it with cable ties (just the brackets sticking out) to act as a gaiter.
Could also be the unitrak bushes but excessive play is more usual here.
wilbur
PostPosted: 22:15 - 29 Nov 2006    Post subject: Reply with quote
Thank you people. Pretty much confims my thoughts. Had a look at it this morning. Yep it is stupidly positioned,as said it gets all the crap. The spring "looks" OK.
I'll give it a few weeks, I dont do a massive mileage. If I need to get it changed I'll probably bite the bullet and pay a man. My knuckles are covered in scars already.
Anyway, cheers.
The last post was made 19 years, 69 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.76 - MySQL Queries: 13 - Page Size: 63.58 Kb
