Replacing head light bulbs
lee.dawson
PostPosted: 19:56 - 26 Jul 2003    Post subject: Replacing head light bulbs Reply with quote
I'm wanting to replace the standard bulbs with halogen bulbs. So i went to the honda dealer and they told me to get halogen bulbs (H4) but when i came to fitting them they have a different connection? Help
one1895
I liked BCF so much I made my own copy
PostPosted: 20:00 - 26 Jul 2003    Post subject: Reply with quote
What type of connection do they have? The standard Honda NSR one's have a 'pop and twist' connection, I'm assuming these are screw connections?
Cam.
Hull & Yorkshire Bikers - Sheffield & Yorkshire Bikers - Manchester Bikers - Nottingham Bikers
TGE125NSR This post is not being displayed because the poster is banned. Unhide this post / all posts.
TJ NSR
PostPosted: 20:29 - 26 Jul 2003    Post subject: Reply with quote
the honda bulbs are bosch fittings...
i'm not sure if you can actually get halogen in the bosch fitting bulbs, the max you can get in there is 12/35/35, where the nsr standard is 12/25/25.. and they aren't that bright standard!
cagiva gezzer
PostPosted: 13:04 - 27 Jul 2003    Post subject: Reply with quote
Have a look in M&P.
Be careful when putting in higher wattage bulbs.
They can draw more power = blown fuses and melted wires.
They produce more heat = melted/warped head lights.
"because one stroke isnt enough and four strokes waste two"
PostPosted: 13:38 - 27 Jul 2003    Post subject: Reply with quote
I've got a feeeling that the main prob with higher power bulbs on the NSR is that they can drain the battery.
I think other poeple have done this (luke?) but the generator doesn't make enough power, so the battery slowly dies.
PostPosted: 13:50 - 27 Jul 2003    Post subject: Reply with quote
Halogen bulbs of the same wattage as the normal bulbs should pull the same power but produce more light. Melting the headlights would not be a good idea Confused
The last post was made 23 years, 59 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.94 - MySQL Queries: 13 - Page Size: 52.07 Kb
