How does reserve work on a NSR?
TGE125NSR This post is not being displayed because the poster is banned. Unhide this post / all posts.
TJ NSR
PostPosted: 22:01 - 26 Jul 2003    Post subject: Reply with quote
usually the tap splits it up, it has two rods coming off it one short one longer, obviously the shorter for reserve and it sorts out litres etc, this is only seen when you unscrew the tap from the tank and put it out.
Shaun
Likes 'em bent
PostPosted: 22:24 - 26 Jul 2003    Post subject: Reply with quote
I really don't think that you should just pull the fuel tap out of the tank!
All I want is a fuel light, is that too much to ask for? I asked if it could be done and they just explained in a sarcastic manner what reserve was for, I insulted them and explained that I wanted a fuel light for convenience not because I didn't know what reserve is for and left!
PostPosted: 22:27 - 26 Jul 2003    Post subject: Re: ahh Reply with quote
TGE125NSR wrote:
Im with you know, so if i pull out the fuel tap i should see two pipes on the top which go inside the tank? One small one and one big one, got ya.
Pretty much, once you have wiped up all the petrol you spill. May be 2 pipes, or may be one pipe with the other just being at the bottom (a pipe of zero length?)
cagiva gezzer
PostPosted: 13:00 - 27 Jul 2003    Post subject: Reply with quote
Reserve is a separate tank.
You have to remember to fill it up after you have used it, otherwise when you need to use it again, it will be empty.
Ha Ha, im soo funny.
When you twist the fuel tap from "on" to "reserve", it just draws the petrol from a lower point in the tank. Usually about 10cm lower.
The last post was made 23 years, 61 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.46 - MySQL Queries: 13 - Page Size: 53.37 Kb
