| butterob |
 butterob Spanner Monkey
 Posted: 00:38 - 30 Nov 2006 Post subject: am i doing this right? |
right im connecting a router to my network (wired) can i just swap this with my modem? and if so will i have to configure any settings?  |
| LustyLew |
 LustyLew World Chat Champion
 Posted: 11:56 - 30 Nov 2006 Post subject: |
That all depends.
Are you using ADSL, or Cable (Broadband)?
You can buy ADSL Routers, Cable Routers and Routers.
IF yous is the 1st or 2nd type, you remove your modem and replace with the router and yes, you will need to reconfigure it. If it is the 3rd type, you need to keep your modem connected.
All the info will be with the paperwork your ISP gave you when you purchased the line. ____________________ Like a Yorkie - I'm not for the girls  |
| dainesefreak |
 dainesefreak World Chat Champion
 Posted: 12:05 - 30 Nov 2006 Post subject: |
It also depends if your router has a built in modem. If the cable from the phone socket fits into a socket on the back of your router then you are away; as long as you haven't got an Ethernet router and a no Ethernet card in your PC.
Easy init.
Edit - Oh and you'd need to know your ISP connection details such as username, password and VCI. |
| techierob |
 techierob Traffic Copper
| butterob |
 Posted: 13:47 - 30 Nov 2006 Post subject: |
| techierob |
 Posted: 14:06 - 30 Nov 2006 Post subject: |
that's very similar to the one I'm currently using on ntl broadband. The build quality is rather bad and it seems to randomly crash whenever the upstream bandwidth picks up so I end up having to regularly reset the router when I'm grabbing torrents. This particular one looks slightly newer though, so I'm guessing they might have fixed that issue.
I'm pretty sure that this particular router won't replace your modem. If you're on cable broadband, then your modem should have a patch cable or a usb cable that leads out of the modem and into your computer. Assuming you're using patch cable, then you just plug it into the uplink port of the router and switch it on then configure the router through the web browser ( https://192.168.2.1/ by default) |
| butterob |
| techierob |
| dainesefreak |
 Posted: 14:22 - 30 Nov 2006 Post subject: |
This is another gateway it won't replace your modem you will have to use a compatible modem and more than likely have to use a CAT5 network cable from this to an Ethernet card in your PC.
You would be better with THIS. |
| butterob |
| techierob |
| butterob |
 Posted: 14:38 - 30 Nov 2006 Post subject: |
does the router go between the modem and the computer?
i only have a usb slot in the back of the modem and another slot for the phone line
right im gonna draw you a diagram and you tell me where im going wrong...  |
| dainesefreak |
| butterob |
 Posted: 14:51 - 30 Nov 2006 Post subject: |
how do i find my information from my ISP...just ring them up and tell them who i am? what sort of information will i be needing?
heres an image of the setup i think i need? tell me if im wrong!
the red circle is gonna be my problem as i dont think that router has USB ports, is there a connector avaliable to change this?
https://i133.photobucket.com/albums/q57/butterob/setup.jpg
[/list] |
| techierob |
| dainesefreak |
| butterob |
| NSR Mick |
 NSR Mick World Chat Champion
| techierob |
| dainesefreak |
| butterob |
 Posted: 15:04 - 30 Nov 2006 Post subject: |
yeah thats the connector that i need ... can u post a link of a cheap one please  |
| butterob |
| NSR Mick |
| butterob |
| techierob |
The last post was made 19 years, 328 days ago. Instead of replying here, would creating a new thread be more useful? |
