PHP help
Gazdaman
I did a trackday!!!
PostPosted: 17:45 - 02 Dec 2006    Post subject: PHP help Reply with quote
Code:
while (($data = fgetcsv($handle, 1000, ",")) !==FALSE) { //fgetcsv returns FALSE on error, including end of file.
   $num = count($data);
   for ($c=0; $c < $num; $c++) {
      if ($data[$c] == $items) {
print "FOUND THE PICTURE IN THE DATA ARRAY! POSITION [b]$c[/b] !!!! See $data[$c] == $items<br />\n";
Ok right, $data[] is an array containing A filename, a description, and a price, a filename, a description and a price...etc etc etc
$items is a filename, and there is code elsewhere, that makes it loop through various different filenames.
So basically, I'm looping through $data[] to find an record that matches $item, then I want to access the record after it, and the one after that. But to do that, I need to access the position.
Anyway, the above code works, but the bold $c always returns 0 when it's actually printed when it literally /can't/ be zero, because in my examples it prints it 3 times, and each time it's a different position in the array. So anyone have any ideas why $c = 0 each time?
Gaz
EDIT: The $c in question isn't in bold, but has bold tags around it.
bazza
PostPosted: 18:10 - 02 Dec 2006    Post subject: Reply with quote
Looks like $c never increments, just the while loop enclosing it, so $c gets reset back to 0 every time the while loop iterates.
Gazdaman
I did a trackday!!!
PostPosted: 18:32 - 02 Dec 2006    Post subject: Reply with quote
I tested it, and c loops between 0 and 2. And the values change each time. There are only 3 values per line in the file it's coming from. So I think it reads the first line into the array (3 values) then the new line starts over again.
So I found a way around that.
Next thing.
$filenames[]="$items";
Should just add the value of $items to the array $filenames. But instead it makes each letter of $items a new field inside the $filenames array.
So the array looks
array[0] I
array[1] M
array[2] G
etc...
Gaz
The last post was made 19 years, 325 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 1.57 - MySQL Queries: 13 - Page Size: 37.24 Kb
