V4/IL4/V2/Para 2/single which is best?
V4/IL4/V2/IL2/single which is best for bike?
V4
24%
 24%  [ 10 ]
In Line 4
39%
 39%  [ 16 ]
V2
9%
 9%  [ 4 ]
Parallel 2
12%
 12%  [ 5 ]
Single
4%
 4%  [ 2 ]
other
9%
 9%  [ 4 ]
Total Votes : 41
kawashima
PostPosted: 17:33 - 04 Dec 2006    Post subject: V4/IL4/V2/Para 2/single which is best? Reply with quote
V4/IL4/V2/Para 2/single which is best for bike engine?
I want to know your preference and reason.
My thought is...
single : no merit at all but lightness(offroad only)
Para 2 : there is no fast bike with this engine.(cheap cost only)
V2(L2) : tasty and torqy at mid range. but not good at low and high.
IL4 : smooth and strong at high rev. but not tasty.
V4 : smooth and tasty. good at all range. best engine.
feef
Energiser Bunny
PostPosted: 17:34 - 04 Dec 2006    Post subject: Reply with quote
which is the best for what?
For off-roading?
top Speed?
Acceleration?
ease of riding?
they all have their own relative merits that will show through depending on the context of the bike the rider and how it's ridden.
a
Mudskipper wrote: feef, that is such a beautiful post that it gave me a lady tingle Laughing
Windchill calculator - London Bike parking
Blog and stuff - PlentyMoreFish dating
Barry_M2
PostPosted: 17:35 - 04 Dec 2006    Post subject: Reply with quote
Seconded.
ZXR750R (M2) - For the road.
CBR1000 RR4 - For the track.
NSR Mick
PostPosted: 17:41 - 04 Dec 2006    Post subject: Reply with quote
I'll third that. Thumbs Up
BorderHooner
PostPosted: 17:42 - 04 Dec 2006    Post subject: Reply with quote
They are all best at doing what they are designed to do.
None are better than a spoon for eating cereal with a slpash of milk. The spoon is best.
Spoon thread Thumbs Down
Benelli. Happy as a pig in cacky.
feef
Energiser Bunny
PostPosted: 17:47 - 04 Dec 2006    Post subject: Reply with quote
Don't try and reply to the thread about the spoon..
instead... only try and realise...
there is no spoon.
Smile
a
TheShaggyDA
Repost Police
PostPosted: 18:09 - 04 Dec 2006    Post subject: Reply with quote
Stacked Transverse V48 Smile
PostPosted: 18:16 - 04 Dec 2006    Post subject: Reply with quote
Honda says a V4 for a road bike as its the best compromise of compact size and power.
Unfortunately its also expensive to produce.
If one engine type was clearly better than another for all applications, then there would only be one type of engine.
mr.z
PostPosted: 18:38 - 04 Dec 2006    Post subject: Reply with quote
Thing with a V4 its a swine to work on, whereas a single is easy to fix (theres a picture of stinkwheel floating about the net with his 2stroke single engine on a park bench undergoing major surgery)
Personally i prefer the delivery of a vtwin, and the noise, thing with the cx is most semi major stuff can be done engine in (headgaskets, clutch, allsorts) the boxer / oposed twin type engine i think i'd quite like, but then if you drop it things can get expensive..
As for parallel twins, a TDM850/900 allthough not that fast is poerfull enough to frighten yourself on and acts much like a Vtwin.. and cb500 have their own race series Laughing
Actually my fave engine is the pan euros transverse V4 Very Happy (and just think of the tuneing potential) But i like the idea of an inline 3 (triumphs) for best comprimise.
One of the things i love about bikes is the diversity, even if a bike dosn't do it for you it works for somebody else, most cars are just cars, only biger or smaller..
PostPosted: 18:56 - 04 Dec 2006    Post subject: Re: V4/IL4/V2/Para 2/single which is best? Reply with quote
Yeah, you didn't mention triples. I like the triple configuaration, smooth, progressive acceleration without the 'deadness' of a four. I particularly liked the triple 2-strokes because they are in balance with a bang every 120 degrees, smooth as a baby's bum. They did have cooling issues though.
You also missed the horizontally opposed twin which has a lot to recommend it for certain uses.
In the end, it's horses for courses, depends what you're going to do with the bike.
My thought is...
Well, I could make some addemdums and corrections
Single: Torque coming out of it's ears from low revs, very tractable with a minimum of gear changing. Often quite vibey.
Paralell twin: Ever heard of an MZ 1000S? They are hardly what you'd call slow.
Fours: To me, they lack character. Also four times as much to go wrong as a single.
irving
PostPosted: 18:59 - 04 Dec 2006    Post subject: Reply with quote
PostPosted: 19:08 - 04 Dec 2006    Post subject: Re: V4/IL4/V2/Para 2/single which is best? Reply with quote
If you want to go fast; the more cylinders the better. So a 4 cylinder bike for best power.
A V4 configuration seems to be adding unnecessary complication and, though does have advantages as far as size goes, but nothing much else.
A V or parallel twin can make similar power.
Generally I find them quite bland to ride.
Singles usually have good low down power in comparison to their peak power (not great in comparison to their capacity often).
If you want to really make the most of a bike, for the vast majority of bikes you do have to rev them; so I prefer a bike that makes it more obvious when you get it right.
Add in other factors like 2 stroke or 4 stroke, number of valves and it all becomes a bit harder to work out.
For instance the RS250 is a v-twin which is very revvy, while a VTX1300 is a very 'un-revvy' v-twin.
My 10 valve head TRX850 twin actually has more of a 'step' in power as it gets to the powerband than many sports 600s (IL4s) do.
McJamweasel
BCF Junkie
PostPosted: 21:15 - 04 Dec 2006    Post subject: Re: V4/IL4/V2/Para 2/single which is best? Reply with quote
Current thinking is that a V4 gives better traction than a standard IL4. Of course, you can make the IL4 'big bang', but that adds to the complexity without the addition benefits of the V4.
PostPosted: 21:43 - 04 Dec 2006    Post subject: Re: V4/IL4/V2/Para 2/single which is best? Reply with quote
That's why I said nothing 'much' else Smile - from my experience of riding bikes with and without such firing orders, I'd say you'd have to be decently better rider than me to be able to make use of the extra traction of a similar engine with a big bang configuration over one without.
Of course, you don't have to have a V4 as a big bang configuration, either, but generally makes sense to do so.
Think the only possible complication with an IL4 big bang configuration is vibration issues?
gavin
PostPosted: 21:51 - 04 Dec 2006    Post subject: Reply with quote
that very much depends on how you define "fast"
the more cylinders you have, the more power you'll get for a given capacity, simply because you increase the ability of the motor to rev with more cylinders, and power is a function of engine speed.
trouble is, that route does not a make for a tractable bike, and on a track alternative configurations may lap faster.
in the real world 2<3>4 Wink
1988 TZR125 : 1990 RD350YPVS/ RGV250 HYBRID : 1982 RD80LC : 1983 RD80LC : 1994 RGV250 : 1991 TZR125 / CR500R HYBRID : 1976 BENELLI 500 QUATTRO : 2006 TRIUMPH 675
mchaggis
PostPosted: 21:54 - 04 Dec 2006    Post subject: Reply with quote
It's a V4 for me I think, for the noise if nothing else.
A howling triple with a racecan raises the hairs on the back of my neck too.
I'm not especially convinced in the parallel twin though, even though the GPZ is rewarding to ride and has a satisfying surge. It doesn't do much for me in the aural department. I like the sound of a high-revving I4 engine in moderation, but it just doesn't have quite the edge to it to grab my attention.
Riding though, I do love the top end rush of a good revvy engine.
To my ear, cylinders of 400cc or more have the biggest effect. Standing six feet behind a TL thou with racecans on and feeling my chest move when it started is something I'll always remember. Shocked
Riding a middle weight Honda V-twin has kind of put me off riding V-twins though, revving it never seemed to achieve very much other than making more noise.
You want to go see an classic 2 stroke 750 GP bike road racing if you want a memorable spectating experience. Shocked Twisted Evil
I must not be a troll...
Mmmm, Guinness
PostPosted: 22:24 - 04 Dec 2006    Post subject: Reply with quote
Getting from A to B quicker. Not talking about quicker as far as seat comfort goes, but going bloody quick.
Don't see why not? Remember, if you're worried about losing traction, you can use less revs.
Ok, it does depend to some degree what some people are confident with - you do need to have a lot of skill to make the most out of a litre 4; but then I still reckon you stick someone on one with similar suspension and they'll be a bit faster than a litre twin.
I believe the 636 is generally considered to be a 'faster' bike than the 675, even if it's a bit less forgiving.
mchaggis:
Try a TRX with race pipes for loud; though that does have the big bang firing order.
My 500 single it seems is a tad unsocially loud with it's race pipe on as well Neutral.
PostPosted: 22:25 - 04 Dec 2006    Post subject: Reply with quote
You want to hear an EX500 motor with a 2-1 marshal deeptone system on it. Like mine Mr. Green.
Torque05
PostPosted: 22:31 - 04 Dec 2006    Post subject: Reply with quote
Voted V4...because of the VMax, sounds great goes even better.... although...
~Sahf East Winnah~
~Yamaha Vmax 1996~
mchaggis
Thinking
Well, since I disintegrated the belly pan, the original system is starting to rust at an alarming pace. A replacement could be in order before too long. Whistle
Mmmm, Guinness
craigs23
Mr Muscle
PostPosted: 22:35 - 04 Dec 2006    Post subject: Reply with quote
No guesses needed for my choice...
gavin
PostPosted: 22:38 - 04 Dec 2006    Post subject: Reply with quote
if a to b means accellerating as hard as you can over a set distance, then yes. but if you're talking about a to b down a twisty country road, then this wont be the case. the 06 r6 may be the ultimate race rep, but on the road, a to b, its crap.
what i mean is, big bhp numbers at high rpm makes a less driveable bike than smaller peak numbers and better midrange.
again, depends on what you mean by faster. on the 1/4 mile, the 636 may be a tenth quicker than the 675, but for in gear roll ons the 675 slaughters the 636, in top from 40-120 its as quick as an R1, and quicker than a gixxer 750.
lilredmachine
PostPosted: 22:59 - 04 Dec 2006    Post subject: Reply with quote
This has very little to do with facts. I prefer a Single in a light frame with some nice sticky roadbike rubber on it. An IL4 bores me, I like v-twins but they don't really come in styles of bike I enjoy...
Rookie
Nothing better than the howl of an IL4, plus if you get an IL4 with some decent torque and midrange, you get the advantages of a V twin without killing IL4 excitement.
Not particularly familiar with V4s though.
PostPosted: 23:01 - 04 Dec 2006    Post subject: Reply with quote
Depends the rider, as I said. Although I'm not an amazing rider, I'm quite happy to try and keep the revs up on the road, even if I'm not 'going for it'. Given a skilled rider they should always be quicker on the more powerful bike until you're getting to stupid power.
If we're comparing similar CCs, then midrange is usually down to the capacity, not the number of cylinders.
Now try it in a gear with the same top speed and see which is quicker Smile.
The last post was made 19 years, 307 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 0.49 - MySQL Queries: 18 - Page Size: 149.53 Kb
