cb125 won't start...heeellllppppp!
uncleboob
PostPosted: 21:27 - 04 Dec 2006    Post subject: cb125 won't start...heeellllppppp! Reply with quote
Hi there
i have just purchased a 1996 cb125 with a kickstart. I didn't think having a kickstart would make that much difference and the guy i bought it off didn't seem to have any difficulty getting it going- oh what a lesson i have learnt!
I scanned through a couple of other posts but cant make sense of them so i thought i'd ask for some new help. As far as i can figure it (i don't have a manual) ive turned the fuel on, there is fuel in the tank, i've turned the ignition on and the neutral light comes on, i kicked the kickstart and there was a little splutter then nothing Sad
I don't know how to tell whether its a single or twin cylinder and I can't find a kill switch, which i'm assuming would be on the (right?) handlebar so what am i doing wrong?
Someone please help, i passed my CBT last week and really really want to go and get some practice
here's hoping
jo
PostPosted: 21:29 - 04 Dec 2006    Post subject: Reply with quote
Is it a Honda CB125 or one of those Chinese efforts?
A CB125 twin will have two plug leads and two carburettors.
Are you using the choke?
PostPosted: 21:33 - 04 Dec 2006    Post subject: Reply with quote
Often people tend to open the throttle as they use the kick start, which generally does not help. Try holding the bars with you right hand such that you are not holding the twist grip.
uncleboob
PostPosted: 21:35 - 04 Dec 2006    Post subject: cb125 non-starter Reply with quote
hi there
no its a proper Cb125, I went for an older proper one rather than a chinese copy on purpose.....HMMmmmm...
i can only find 1 spark plug so i guess that means its a single does it? And yes i did use the choke, but on or off didn't seem to make any difference, could i have flooded the engine?
If its flooded what should i do to make it better?
take care
joj
veeeffarr
PostPosted: 21:46 - 04 Dec 2006    Post subject: Re: cb125 non-starter Reply with quote
uncleboob wrote:
hi there
take care
joj
Is it a CG125?
Give it a good firm kick, you won't break it.
I found my CG started easier with a TINY bit of throttle while kicking
PostPosted: 21:47 - 04 Dec 2006    Post subject: Reply with quote
Which of these two?
https://i48.photobucket.com/albums/f216/stinkwheel/cb125.jpg
Robert2014
PostPosted: 21:50 - 04 Dec 2006    Post subject: Reply with quote
Hi there il let u in on a little Tip i use my self on kick start bike's ok what to do is Take the Spark Plug out if it's Wet HEat it up and put it back in after say 2 or 3 Kick's Should fire up Stright away and let the bike Warm up or even better take it a run even if the plug is not wet Still heat it up with a lighter and stick it in Allway's work's for me i used to do it to a Chitum i had and that was a 04 plate even it was STolen Reovered lol but still done the trick Failing that if that still dose not do anything Find a hill Or Get sum one to give u a push once u get Going Knock the Bike into Second Gear and let the Cluch out should fire up that way i hope this has help u out
If you require a mechanic then I am your man. Bike collection and recovery service available. Don't let a monkey work on your bike, call the family run business on 07778 873 184 01505684994 https://www.rdbikes.co.uk info@rdbikes.co.uk
PostPosted: 22:05 - 04 Dec 2006    Post subject: Reply with quote
Actually, it isn't a twin because only the really early twins had kick starts. I think Toby R must have it, it'll be a CG125. I don't think they were still making CB125 singles in 1996.
Yeah, you probably flooded it. Either switch the fuel and choke off, hold the throttle wide and kick it maybe 20 times until it fires up or switch the fuel off, leave it to stand for half an hour or so then try again.
Or, as RD_bikees says. Take the plug out and give it a clean then try again.
uncleboob
PostPosted: 22:18 - 04 Dec 2006    Post subject: ...and the bike is......a CG 125!!! Reply with quote
What a donut!
I've just checked back and you are all indeed correct it is a cg125 not a cb125...and looks like the first picture...if it were a twin would it have two exhausts?..as mine only has one and one spark plug.
so assuming i've flooded the engine, by tomorrow the fuel would probably have exaporated? If so what should my start up routine be? If it continues to struggle is that indicative of something?
its a real shame 'cause as cg's go this seems to be in quite good condition, bodywork is straight, chrome is shiny etc etc, must admit though, right now i'd rather have a rusty working one...preferably with an electric start!
i've added some picky's
Robert2014
PostPosted: 22:31 - 04 Dec 2006    Post subject: Reply with quote
the Good old Cg's Right What to do is Dose not matter if u have Flooded it or not Take the Plug out Clean it and then Heat it up with a Lighter and then Stick it back in Kick it over a Couple of time's and Will Fire up Stright away no need for Choke But u can use a little bit of it Would Like to hear how it go's if u could post a wee message back on here please Cheer's RD BIKE's
veeeffarr
PostPosted: 22:35 - 04 Dec 2006    Post subject: Re: ...and the bike is......a CG 125!!! Reply with quote
uncleboob wrote:
What a donut!
Make sure that the choke isn't on.
Have a feel under the left hand side of the fuel tank, there's a small grey metal lump underneath (Your carb) with a flat bit of black plastic that flicks up and down.
This is your choke.
FULLY DOWN is off.
Make sure it is fully down, if it isn't, do so and then kick the bike over with a little throttle.
uncleboob
PostPosted: 22:40 - 04 Dec 2006    Post subject: starting the cg125 Reply with quote
Thankyou everyone for the tips,
if if wasn't so late i'd pop out now and give it a go, but my wife would be upset and the neighbours would complain!
Anyway, i'll try ALL the tips tomorrow (i've taken a day off from work to play) and let you know how it goes...hopefully it will go!
thankyou very much
take care
jo
veeeffarr
PostPosted: 23:27 - 04 Dec 2006    Post subject: Re: starting the cg125 Reply with quote
thankyou very much
take care
jo
Wife would complain about the sound of a CG125 starting!?
Jesus, hope you don't breathe in your sleep! Razz
Paddy Blake
PostPosted: 01:15 - 05 Dec 2006    Post subject: Re: starting the cg125 Reply with quote
thankyou very much
take care
jo
Fart and the police will be around. Laughing
Compo
PostPosted: 21:31 - 05 Dec 2006    Post subject: Reply with quote
One more thing make sure the kill switch is not in the off position.
ta
Compo
uncleboob
PostPosted: 22:00 - 05 Dec 2006    Post subject: ......and the result is?..................... Reply with quote
.....well i tried all the suggestions and guess what? I've just spent the evening riding around on my bike! Yeah, just me and the 40mph beast that is my cG125
thankyou all for your excellent help and kind support, without it i'd still be staring at my non-working bike!
As an aside, i did notice that after a while the bike began to splutter, lurch a bit and struggle, almost as if not enough/ too much fuel was getting into the engine, any ideas why this might be? I was thinking carb if the bikes been sitting for a while- could that have made the internal gubbins sticky? Although for the first 10-20mins all seems okay??? I checked the petrol and there is definetly enough in there- so once again am stumped!
once again thankyou for the top tips and support
jo
befdelta7
PostPosted: 22:25 - 05 Dec 2006    Post subject: Reply with quote
the obvious first -- make sure the fuel is put to 'on' or 'reserve'
would be worth replacing the spark plug, and clean the float bowl(bottom of the carb) and the internals of the carb and also clean the air filter, its probably clogged up with road grime and dirt.
that'll help the beast run well LOL Thumbs Up
Dont do a wheelie in front of a traffic copper... it gets you 3pts and £220 fine.
Paddy Blake
PostPosted: 22:41 - 05 Dec 2006    Post subject: Reply with quote
It would be worth doing a full service including the tappits.
Paddy.
Robert2014
PostPosted: 23:44 - 05 Dec 2006    Post subject: Reply with quote
Hiya Just Wondering Did it Start up First time when u wen't out to it this morning ?????????????? Or who's Advice did u Take to get it Running ???? Please let us no
PostPosted: 23:47 - 05 Dec 2006    Post subject: Reply with quote
If the bike has been sat for a while, it would be worth topping up the fuel tank with fresh petrol. Unleaded petrol can 'go off' within a couple of months.
veeeffarr
PostPosted: 00:08 - 06 Dec 2006    Post subject: Reply with quote
What did you do to get it running?
uncleboob
PostPosted: 09:06 - 06 Dec 2006    Post subject: fixing the beast :) Reply with quote
Well, it didn't start straight away when i went back to it,
it just kinda backfired and then gave up! SO i tried to remove the plug, but for some reason my plug socket didn't fit so i couldn't get it out. By this time the battery was becoming V V weak, so i did as suggested and turned everything off and started from scratch.
This time i really gradually increased the choke each time i kicked it over until i found the point at which it began to catch, a few more kicks and it fired up! Hurrah!
I made sure to keep off the throttle and made sure i rested the engine for a bit when trying to start with the choke, so that it didn't flood again.
I reckon i still need to service it, especially since it keeps stuttering, so next day off i'm going to investigate taking the plug out, possibly fit a new one, will check out the carb and maybe think about changing the fuel.
Would i have to empty the fuel out altogether, or just put some new stuff on top?
thankyou everyone- i'll keep you updated with any progress
take care
jo
PostPosted: 18:05 - 06 Dec 2006    Post subject: Reply with quote
I'd just top the tank up with fresh fuel. Otherwise you'll be left with a load of petrol lying about and nothing to do with it.
uncleboob
PostPosted: 22:04 - 06 Dec 2006    Post subject: continuing cg125 woes Reply with quote
Hi again
why is it that things always go wrong when your furthest away from help? I took the cg out again this evening confident that all was well-ish and trusting the bond between man and machine...........
.............i should have known better!
Initially all was well, the bike accelerated without any problems, it was a little reluctant at first but then seemed to clear its throat a little and away we went. After plodding around for 30 mins i decided to turn back home and thats when it all went wrong.
The bike would go into gear fine, and would creep along happily, but as soon as the throttle was applied the revs would die right down to the point of almost stalling.I had to half push, half coast the bike all the way home at a top speed of about 2 miles an hour!
I've now topped up the fuel, there wasn't a great amount left so i'm thinking mixing old and new wouldn't make too much difference.
Any ideas about what has gone wrong? I'm thinking of putting it in for a service tomorrow- hoping that its something simple!
take care
jo
The last post was made 19 years, 43 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.11 Sec - Server Load: 0.87 - MySQL Queries: 13 - Page Size: 133.24 Kb
