only 100 PLEASE HELP !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
guest
Guest
PostPosted: 10:27 - 03 May 2002    Post subject: only 100 PLEASE HELP !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! Reply with quote
your site says a 14 tooth front sprocket and it will go at 110 mph i got a chain and sprocket set with a 14 tooth f sprocket an at just under redline its struggling at 98-100mph do you get 110 well into the red line or do you think the sprocket set i got has a different amount of teeth do you know how many it should have to do 110mph cos i noticed a slight reduction in accelleration and fuck all top end increase is this possible its dsoing my head in my mates are getting 125s soon i want to be faster please help
guest
Guest
PostPosted: 10:29 - 03 May 2002    Post subject: Reply with quote
i mean how many teeth should the back sprocket have it deffinately has 14 at the front
Dan
PostPosted: 10:55 - 03 May 2002    Post subject: 1 Reply with quote
there is no pleaseing some people Rolling Eyes
Keen
PostPosted: 15:38 - 03 May 2002    Post subject: Reply with quote
the less teeth at the back the faster top speed- thats right isn't it? the mito has 38 teeth (I know cos I'm gonna get a mito sprocket for my planet, which has 43 teeth standard) so the NSR should be the same I'd guess.
PostPosted: 22:33 - 03 May 2002    Post subject: Reply with quote
Yes a smaller rear and / or larger front sprocket will give a higher top speed at the expense of acceleration (assuming the bike has the power).
However, the overall gearing of a bike is also dependent on the actual gearing of each individual gear, combined with the primary drive ratio (ie, crank to gearbox gearing). This varies greatly between bikes
The last post was made 24 years, 158 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.81 - MySQL Queries: 13 - Page Size: 41.79 Kb
