Suzuki RG 250 engine removal problems
 Topic moved: from Forum Feedback & Help to The Workshop by EuropeanNC30Rider (7 Dec 2006 - 08:52)
at_lowe
PostPosted: 05:36 - 07 Dec 2006    Post subject: Suzuki RG 250 engine removal problems Reply with quote
Hi ppl, I'm new here so here goes nothing!
I've got the above bike with alloy frame and can't figure out how to remove the engine from the frame! No matter which way I go, the engine's just too big to fit through a hole! Where am i supposed to support the engine when I unbolt and and from which direction should it be removed? The carbs have been removed and pretty much everything else, but because of the bolt-on points that attach as little triangles from the framework I can't seem to see anywhere to push/pull it. Any help for this pain of a problem would be really appreciated.Thanks!
finpos
PostPosted: 09:07 - 07 Dec 2006    Post subject: Reply with quote
Got a photo?
You should look around the engine to see if the engine mounting bolts had any spacers between the frame and the engine - these often stick in place after you've taken the bolt out. Knocking the spacers out may gives you the vital extra cm you need.
Also, totally remove any mounting brackets (little triangles?).
finpos.
sickpup
Old Timer
PostPosted: 09:59 - 07 Dec 2006    Post subject: Reply with quote
Take the head and barrels off and its a very easy. Had two of them.
The last post was made 19 years, 62 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.11 Sec - Server Load: 1.04 - MySQL Queries: 16 - Page Size: 35.21 Kb
