| pa_broon74 |
 pa_broon74 World Chat Champion
| Marci |
 Marci Brolly Dolly
 Posted: 12:05 - 15 Dec 2006 Post subject: |
How are we expected to answer when you don't tell us what bike it is that you're talking about?
Tried bump starting it (stick it in third, run alongside with it in gear and clutch in & ignition on, dump clutch and pull it back in again)? ____________________ FAB-Racing MiniMotoSidecars - Back with a vengeance - F1 Class 2011...
CBR170 engine, custom chassis - www.minimotoscene.co.uk |
| pa_broon74 |
 Posted: 12:18 - 15 Dec 2006 Post subject: |
Its a Honda CLR 125.
I suspect that if you can jump start one 125 from a transit van it pretty much counts for all of them.
As you may already have gathered, its a 125. If you try to bump start it, the back wheel just skids; its not heavy enough to bump, (you have to sit on it.) In this instance its not practical to bump it anyway.
I ask because in order to find the fault I have to rule things out, if I have to charge the battery between each fault finding excercise i'll be there till xmas day.
| finpos |
 finpos World Chat Champion
 Posted: 12:38 - 15 Dec 2006 Post subject: |
Watch, this question normally starts an almighty hoo-haa.
As long as the van battery is 12V, no problem at all. If it's 24V, best not to
EDIT - just saw your other thread - The van battery will tell you in double quick time if the problem you are having is a wheezy battery, which does sound to be the case. Sometimes, when the battery is on it's last legs, the plug will spark when it's out of the engine, but as soon as you put it back in (starter now has to overcome compression and so takes more current) the wee spark pixies disappear.
finpos. |
| veeeffarr |
 veeeffarr Super Spammer
 Posted: 12:45 - 15 Dec 2006 Post subject: |
| pa_broon74 wrote: | Its a Honda CLR 125.
It's only a 125, you should be able to waddle in 2nd gear with the clutch in and then dump it. |
| MattEMulsion |
 MattEMulsion World Chat Champion
| krebsy |
 krebsy World Chat Champion
 Posted: 12:55 - 15 Dec 2006 Post subject: |
Once upon a time my family went off on holiday and the Volvo was parked up for a week in Penzance. when we got back to the car the dodgy battery was flat and my dad asked around for someone to jump start the car. Up rolls a land rover with a huge battery pack in the rear and a massive length of cables.
Two cables onto the battery and started first time. Then the driver told us what the land rover was for. we were at the Heliport and the electrical gear was used to start the 20 seater british airways Helecopter we had just arrived back from the isles of Scilly on..
Shame the car started miss-firing by the time we got to Bristol. My dad decided it was best to drive back to the North-West without stopping as he didn't want to risk the engine dying on us..
K. ____________________ What's my New Year's resolution?
1280 x 1024. |
| pa_broon74 |
| Mooncatt |
 Mooncatt Brolly Dolly
 Posted: 13:04 - 15 Dec 2006 Post subject: |
i tried bump starting my 400 a few months ago nearly dropped it  ____________________ current bike...CBR400RR
"you always need more chicken" |
| finpos |
 Posted: 13:21 - 15 Dec 2006 Post subject: |
That same honda dealer will order you a bargain basement pattern part instead of the honda one if you actually ask them,,,
Well worth doing with batteries by the time you have paid for postage / hassled yourself with getting hold of acid.
BUT just satisfy yourself that the battery is at fault first by charging it. It may just have gone flat just this once (because you have startign problems), or there could be a problem with the charging on the bike.
finpos. |
| Blau Zedong |
 Blau Zedong Banned
| G |
 G The Voice of Reason
| pa_broon74 |
 Posted: 15:07 - 15 Dec 2006 Post subject: |
Mmm...
The last time it had sat for 2 weeks without being used. The battery was wheezing so I charged it, tried to start it then repeated this process 5 or 6 times while trying to bump start it (in first and second) in between times.
Eventually, someone here suggested it might be the spark plug. I bought another one and stuck it in. Managed to get it going, although, it did flatten the battery again and I ended up bump starting it.
It did occur to me that maybe the battery wasn't charging, but it's been fine since I changed the plug. How can you tell the difference between a faulty battery and a fault with the bike's charging bits, (highly technical jargon there probably cheaper to buy a new battery first. (wemoto do one for £28.)
I'll try jump starting it off the van, as finpos said, that would confirm the battery's at fault. I'll get another one anyway, I don't think it's ever been renewed.
Thanks again folks. |
| Syx |
 Syx World Chat Champion
| pa_broon74 |
 Posted: 15:55 - 15 Dec 2006 Post subject: |
Aye...
When I read it back to myself I thought it kinda looked like that too. I failed English, what can you do...
As I recall, when I was trying to bump it, the ground was damp. I wish I could say that the weight of my svelte body astride the machine still didn't provide enough traction, but I'd be talking crap.  |
| pa_broon74 |
| finpos |
| cagiva gezzer |
| pa_broon74 |
| finpos |
 Posted: 13:24 - 19 Dec 2006 Post subject: |
Getting a belt off it is the slightly more painful way of doing it than looking at it in the dark, but it tells you the same thing
I don't think you can buy just the cover, you'll need to replace the whole cap. having said that, it's the caps's job to stop the electricity leaking, not the rubber boot, that's just there to keep it dry. Make sure the boot is not full of water, and check the cap to see if it has any cracks, pits or black (carbon) staining on it, which is a sign it's being shorting out.
Depending on how flush you are, you can either spend a while dicking around with it to try and find out what's breaking down, or just spend 10 quid on a new ht lead and plug cap. Up to yourself.
Plug might be new and look ok, but they rely on proper combustion to keep themselves clean. They can go off very quickly in a misfiring engine. Again, up to you if you want to replace it.
With the battery going as well, sounds like you're just having a bad case of 5-year-old bike
finpos. |
| djneu-trix |
 djneu-trix Spanner Monkey
| djneu-trix |
| pa_broon74 |
 Posted: 15:08 - 19 Dec 2006 Post subject: |
Thanks folks.
I'll swap the ht lead and get another plug. I think I'll service it properly too, I haven't changed the oil for a while (eh, about 3000 miles since I got it ) on account of the sump plug being stuck fast: I'll make more of an effort to get it off.
I think I'll have another go at charging the battery, I have a sneaky suspision that the charger was set to "slow" charge which may have skewed my rigorous testing process... Ummm
All this cold and rainy weather, I'm not surprised that its playing up, heck: I have a hard time getting going in the morning these days too.  |
The last post was made 19 years, 245 days ago. Instead of replying here, would creating a new thread be more useful? |
