RESTRICTIONS
Scooby
Scrappy Doo
PostPosted: 23:45 - 03 May 2002    Post subject: RESTRICTIONS Reply with quote
Where abouts is the exhaust restrictor, coz if the weathers good I wanna have a go at derestricting my bike tomoz!!!
Is it in the actual end can, or in the bit where the exhaust bolts onto the engine???
Vrooom
PostPosted: 00:16 - 04 May 2002    Post subject: Reply with quote
The restrictor is in different places in the exhaust depending on the bike make and model. But usually it is near a join in the exhaust so just undo the bolts and look down the exhaust and you should see a small washer limiting the gas flow. Some are easier to get at than others.
hope this helps
cheers
Vrooom!
Scooby
Scrappy Doo
PostPosted: 11:28 - 04 May 2002    Post subject: Reply with quote
Sorry, I couldn't get on NSR125.com earlier to check the de-restriction guide, I guess Korn might of been fiddling again lol, but I can get on now, so i've printed out the guide......wish me luck.....
craigT19
Jolly Green Giant
PostPosted: 15:37 - 04 May 2002    Post subject: ..... Reply with quote
Vrooom wrote:
But usually it is near a join in the exhaust so just undo the bolts and look down the exhaust and you should see a small washer limiting the gas flow. Some are easier to get at than others. !
ummmm small washer?????? if you took out the washer type thing put it back its you exhaust gasket it give you an air seal where the exhaut joins the engine block.
take off the exhaust and look down it your see a big metal tube stuck in side the exhaust, this is not easy to get out.
its a long metal tube with a metal ring welded at either end. its usually about 5 inches long as it actually goes down in to the first bend.
Bikes owned :- 2001 nsr125, 1999 zx6r, 2006 yzf-r1, 2009 xmax 250, 2012 yzf-r1, 2015 MT-07
Current bike : - 2016 MT-10
Crying or Very sad BCF member pops. sadly missed Crying or Very sad 1945-2003
Scooby
Scrappy Doo
PostPosted: 16:08 - 04 May 2002    Post subject: Reply with quote
Ok i've managed to get the exhaust restrictor out, (i am typing this with my hands covered in oil and carbon crap lol you should see the state of my keyboard, oh well) It took me ages, well it seemed to anyway. 4 drill bits it took, damn things.
Hmmmm I'm a bit wary about doing the air intake I don't like the sound of all this detach the fuel hose, and leave the carb dangling business.... Confused
How long should it take to remove the air intake restrictor??? Should it be quicker than the exhaust restrictor???
TJ NSR
PostPosted: 17:30 - 04 May 2002    Post subject: Reply with quote
it shouldnt take too long, shorter than the exhaust, dont loose any screws!
The last post was made 24 years, 159 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.25 - MySQL Queries: 13 - Page Size: 47.25 Kb
