exhaust protection!
djneu-trix
PostPosted: 15:49 - 18 Dec 2006    Post subject: exhaust protection! Reply with quote
hi everybody!
quick question!
my exhaust pipe is a painted black pipe and its got quite a bit of surface rust on it, i was wondering what is the best way to restore/preserve it as there very hard to come by!!!
thanks
pg
Trixie
PostPosted: 15:56 - 18 Dec 2006    Post subject: Reply with quote
Rub it down and rust treat it (if its bad enough to need it). You can then get heat resistant black paint to repaint the exhaust. Thumbs Up
Dead nobodies in company cars...
djneu-trix
PostPosted: 15:59 - 18 Dec 2006    Post subject: Reply with quote
yer kool thats what i thought!
ive been told that thhe rust treatment stuff is not a good idear to use on exhaust becuase there so thin! should i just ignor that then and go ahead!!!
which treatment do people advise to be the best as i only use the best on this bike!??????
thanks!
pg
finpos
PostPosted: 16:26 - 18 Dec 2006    Post subject: Reply with quote
Trixie's advice is fine, but you can expect to do it every year. Once your mild steel exhaust starts to rust, it's a slow death for it.
Simply put, the only stuff that will stick to it is high temp paint. The only way you will get the exaust clean enough for high temp paint to work properly is to get it shot-blasted, and if the exhaust is a few years old, that'll put holes in it.
So, in my opinion;
1. Spanking new stainless pipe. Lovely.
2. Quick razz with a wire brush on a drill, mop on B+Q BBQ paint, repeat next year. Use more expensive paint if you want, but it'll still end up on the floor. Less lovely but considerably cheaper.
I had an exhaust delivered to me once and there was a note in the box saying that the paint on it was "for cosmetic purposes only", so
I managed to save that one by stripping and re-painting it properly before any rot set in.
finpos.
djneu-trix
PostPosted: 16:31 - 18 Dec 2006    Post subject: Reply with quote
quality!!! BBQ paint! i never thought of that!! high temp paint is only about £6 a can! looks like im just gunna give it a wire brush and a lick of paint! i dernt shotblast it it dont look that clever!
if you can find a new exhaust for a honda ns125 then bring it on! would love a micron or sumting!!!!
thanks for your help!
pg
loply
PostPosted: 23:04 - 18 Dec 2006    Post subject: Reply with quote
I might be wrong but I don't imagine sandblasting (relatively lightly) would hole an exhaust, not if you're remotely careful.
I built a sandblasting cabinet that I run a 116-psi blaster with various grits from, and though it cleans the bollocks off anything I blast with it, it really makes immeasureable difference to the thickness.
I guess if you used some industrial pressure-pot thing with a hard abrasive you might eventually blast through though.
Personally I'd give it a shot - But then, maybe the poster doesnt have access to sandblasting facilities.
Yamaha SZR660 Caution to the wind, the throttle pinned!
djneu-trix
PostPosted: 23:11 - 18 Dec 2006    Post subject: Reply with quote
sadly not any more! Sad use to be a welder and there was a whole massive workshop for sand blasting! used to make pontoons and boats etc. I never did anything myself in there (blasting) but i got a bloke to to my old bmx frame! it left it really rough!!! that stuff would deffo blow holes into it even though it is just surface rust. would be nice to get it blasted but im really paranoid that if i do and it does produce loads of holes, that i wont beable to get a new exhaust!!!
i cant find a new/second hand 1 anywere!!!!!!!
i dont mind how much it cost!!!!! (to an extent)
think i will have to stick with the brush and paint idear and just keep ontop of it!
Sad
pg
finpos
PostPosted: 23:20 - 18 Dec 2006    Post subject: Reply with quote
loply - 2-3 years from new, and with a light grit, I'd think no problem at all. Much older that, the combination of internal and external pitting turns exhaust downpipes into teabags.
If you're never blasted through rusty sheet steel, you're really not trying hard enough. Smile
finpos.
satans_BIG_helper
PostPosted: 12:29 - 19 Dec 2006    Post subject: Reply with quote
I would just wire brush the rust off clean it all up prep it nicely, treat any bad rust then paint it with either wilkinsons BBQ paint as from my experience it is by far the best or use blackboard paint which is a bit of a bugger to use as you have to paint it on whereas the BBQ paint sprays on and gives excellent results Smile
djneu-trix
PostPosted: 13:25 - 19 Dec 2006    Post subject: Reply with quote
bbq paint it is then!!!!
thanks every 1!!!! Very Happy
pg
djneu-trix
PostPosted: 13:26 - 19 Dec 2006    Post subject: Reply with quote
but what is the best treatment to use????
pg
finpos
PostPosted: 13:36 - 19 Dec 2006    Post subject: Reply with quote
In my opinion, don't bother.
1. If you put a chemical treatment on it, and then paint over the top of it with heat resistant paint, then there's a very good chance the chemical stuff will react with the heat and lift off the paint. That's why the surface must be immaculatly clean (blasted/new) for high temp paint to work right.
2. Given that you'll never get it clean enough, and you'll be doing it again next year anyway, save yourself the 6 quid the treatment costs.
finpos.
djneu-trix
PostPosted: 13:37 - 19 Dec 2006    Post subject: Reply with quote
top stuff!!!
cheers finpos!! Smile
pg
The last post was made 19 years, 248 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.12 Sec - Server Load: 0.15 - MySQL Queries: 13 - Page Size: 81.72 Kb
