| ColdInsomnia |
 ColdInsomnia World Chat Champion
| kat250 |
 kat250 World Chat Champion
 Posted: 13:42 - 17 Dec 2006 Post subject: |
Carb icing tis the season and all . could be crab blocking your jets but my guess would be carb icing. Get some adidtive from a garage, cant remember the name off the top of my head. ____________________ in the famous word of jimmy pop "would you F*ck me for blow"
In the words of banditshigh "would you blow me to f*ck" |
| ColdInsomnia |
| Kickstart |
 Kickstart The Oracle
 Posted: 14:04 - 17 Dec 2006 Post subject: |
Carb icing is not as common as people think. For you to get carb icing it needs to be cool damp weather. Too cold and there is not enough moisture in the air for the icing to occur. Added to which the Divvy has an electric carb heater. Also this would likely occur at speed and would likely fix itself for a short while after sitting at low speed / in traffic for a while.
While possible it would not be the first thing to check.
Personally I would suspect the dodgy fuel pump if it has one of the vacuum operated ones fitted to a lot of Divvys. Check the vacuum pipe from the inlets to the pump. Also open the fuel cap and check for a vacuum in there (sign of a blocked breather hose).
| Kickstart |
 Posted: 14:08 - 17 Dec 2006 Post subject: |
| ColdInsomnia wrote: | I did think it could be icing since it was so cold last night. But I figured that, well, once the engine was started and had a while to run the ice would have surely melted? |
Nope. Carb icing is caused by the flow of air through the carbs and the petrol coming from the carbs taking loads of heat with them, reducing their temperature greatly. So much that the moisture in the air condenses and freezes in the carbs. It is not a problem that will happen immediatly when you start the engine, rather a problem that occurs when the engine has been running for a while, normally at some speed.
Low speed running will often allow enough heat from the engine to soak up to the carbs to cure then problem. Same for stopping and leaving the bike for 5 minutes.
| ColdInsomnia wrote: | I did run the petrol tank down to nil yesterday (had to push it to a petrol station, only about 50 yards :p ), so perhaps there is still some air working it's way through the engine (complete guess) ?? |
Err, add a blocked fuel filter to the top of the list of most likely causes, along with the possibility of water in the carbs (although that would have caused a problem from when you switched to reserve).
| davidimurray |
 davidimurray Nitrous Nuisance
| stinkwheel |
| krebsy |
 krebsy World Chat Champion
| yambabe |
 yambabe World Chat Champion
 Posted: 14:03 - 18 Dec 2006 Post subject: |
This sounds like one of the (many) problems I had with my bike whilst we were still running it in this year.
In my case this particular problem was caused cos the fuel breather pipe had become detached.
Being about as tech-minded as a housebrick I have no idea why this caused a problem, but I know it was perfectly OK again once the pipe had been reattached.
Might be something to check and tick off your list of possibilities at least. ____________________ Sod falling in love, I wanna fall in chocolate.  |
| puremagic72 |
 puremagic72 Brolly Dolly
 Posted: 19:42 - 18 Dec 2006 Post subject: |
Mine died twice in motion the other week, turned out to be the alternator was burned out, and not charging the battery up.
Fixed now and no probs, but as for the switching of the fuel, no idea!
Being as cold as it is, its mostly battery type problems.
Baz.  ____________________ Make; cbr929cc blade Year; 2001
Gsxr 750 2000, alstare Corona, Current bike 1999 R6
(1) Kids in the back seat cause accidents; accidents in the back seat cause kids. |
The last post was made 19 years, 247 days ago. Instead of replying here, would creating a new thread be more useful? |
