Black smoke out of exhaust
funmonkee
PostPosted: 20:38 - 18 Dec 2006    Post subject: Black smoke out of exhaust Reply with quote
...is black smoke on these icy damp cold nights normal after a 20 minutes run? The bike starts up fine and the fumes are clear on startup (in the morning), but when I get home after 6ish..the fumes are black... oil contamination? BTW its my 'max
**** Don't ride faster than your angel can fly Get this Free Space
The democratically elected Mod of the Scottish Section - The Peoples Choice[b]
hazza
PostPosted: 21:14 - 18 Dec 2006    Post subject: Reply with quote
if it were oil i would imagine you would be getting alot of white smoke with a distinct smell of oil, black smoke usually means your running mega rich
geordiecbrblo...
PostPosted: 21:18 - 18 Dec 2006    Post subject: Reply with quote
^^^ what he said.
Black fumes are unburnt fuel, are you using a lot of petrol?
funmonkee
PostPosted: 21:22 - 18 Dec 2006    Post subject: Reply with quote
geordiecbrbloke wrote:
^^^ what he said.
'bout the same as my old 4 litre cherokee..Thumbs Down but then I have the Tboost set to 3k, for Vboost in half the time Smile I do smell a bit of petrol sometimes... I'm a noob with checking stuff. Will see if I can get somelocal help with your suggestions Thumbs Up cheers Karma
Al
Agree, yep black smoke is normally rich mixture.
Burning oil is normally blueish color smoke.
white smoke is normally steam/moisture.
Yamaha FZR400RR 3tj
My Instagram Thingy
funmonkee
PostPosted: 21:29 - 18 Dec 2006    Post subject: Reply with quote
Would that also explain why the 'max has stalled itself at lights twice last week (very embarrassed me:oops:).?. Also the power is just pants these days:down:; I seem to give it some throttle and wait a few second then it shots off like a cartoon character...not so great in town...nice out on the open bypass Karma
cheers people Karma Thumbs Up
finpos
PostPosted: 21:52 - 18 Dec 2006    Post subject: Reply with quote
Hmm, worst case is your are getting compression in the crankcase due to leaky piston rings. Compression test will tell you if that is the case quickly enough Sad
You can try to take a look at your oil level, also see if your airbox is full of crap.
finpos.
funmonkee
PostPosted: 21:59 - 18 Dec 2006    Post subject: Reply with quote
finpos.
How do I test the compression? I have no compression testing tools in my garage! Thumbs Down
funmonkee
PostPosted: 22:02 - 18 Dec 2006    Post subject: Reply with quote
btw I've been losing alot of cooling fluid,,,can't find a leak I just keep topping up. about an two or three inch each week Embarassed I've topped up the oil just in case. Am a bit scared of the whole breaking another engine thing Thumbs Down
finpos
PostPosted: 22:06 - 18 Dec 2006    Post subject: Reply with quote
You'll need to take it to a bloke with a compression tester. The coolant loss may or may not be related, but comes under the general heading of "not good"
finpos.
Paddy Blake
PostPosted: 22:17 - 18 Dec 2006    Post subject: Reply with quote
Check if the choke cable is sticking on.
funmonkee
PostPosted: 22:24 - 18 Dec 2006    Post subject: Reply with quote
promise choke is off. i do warm it up with the choke on about a quarter for a few minutes. have no thermostat in it since i had problems with overheating. Thumbs Down
finpos
PostPosted: 22:31 - 18 Dec 2006    Post subject: Reply with quote
That'll be doing it the world of good as well.
finpos.
funmonkee
PostPosted: 22:33 - 18 Dec 2006    Post subject: Reply with quote
finpos.
erm yeah. But as long as I warm it up properly it'll be okay right? Now am worried (again) Thumbs Down
finpos
PostPosted: 22:44 - 18 Dec 2006    Post subject: Reply with quote
Thermostat is kinda important. What you might find is that removing the 'stat actually created short circuit in the cooling system, so all you did was to pump more, cooler water past the sensor (gauge now looks ok) while starving the engine of that very same cooler water, i.e. you overheated the engine even more.
Stat out is ok for diagnosis/bodging, I wouldn't run an engine I wanted to keep like that. Definitely not a fix for overheating.
finpos.
funmonkee
PostPosted: 22:50 - 18 Dec 2006    Post subject: Reply with quote
nuff said Thumbs Up will probaby put it back in tomorrow. going to change oil/ filter etc and check a few other things.
veeeffarr
PostPosted: 23:50 - 18 Dec 2006    Post subject: Reply with quote
Have you checked the air filter isn't blocked?
funmonkee
PostPosted: 23:58 - 18 Dec 2006    Post subject: Reply with quote
History: the engine was busted a few months ago and got a full rebuild with replacement bits from my other fook'd max!!! Embarassed
I've changed the oil once since the rebuild. So...
Tomorrow I go in search of
oil
new oil filter
check the airfilter
reinstall the thermos
check the mix of the fuel/air/carbs
choke cable no stickin
etc
will get back and update....
oh aye and i've got a slow rear puncture... joy
Karma
The last post was made 19 years, 246 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 0.26 - MySQL Queries: 13 - Page Size: 99.64 Kb
