what is it and why does it smell of fuel
P_J
PostPosted: 22:03 - 31 Jul 2003    Post subject: what is it and why does it smell of fuel Reply with quote
The very first time I dive under the tank and decide to strip something down, i get stuck.
That huge black box under the tank of my NSR, now, whats inside that,,, nothing. i got a kind of vent facing to the rear of the bike, a lump o sponge, and a stink of petrol.
Im assuming its an air filter, but not like ive ever seen in a car of was expecting to see on a bike. what good is a crappy little bit of foam gonna to. and why does it smell of petrol. is it ment to? do i wash it?
I know i cant learn without having a go but i think id feel safer with a haynes manual (or equivelant).
Dreams will get you nowhere, a good kick up the arse will take you a long way.
Only1PJ.co.uk
McJamweasel
BCF Junkie
PostPosted: 22:09 - 31 Jul 2003    Post subject: Reply with quote
That, my anally retentive friend, is your airbox. And it smells of petrol because it leads directly to the carb.
And that bit of foam is indeed the air filter. Try washing it out and you'll see what it will do for you.
TGE125NSR This post is not being displayed because the poster is banned. Unhide this post / all posts.
P_J
PostPosted: 22:12 - 31 Jul 2003    Post subject: Reply with quote
its actualy soaked in fuel though.
Squeeze it and it would drip all over.
how can the carb spew fuel that far?
Surely the filter being wet isnt right?
Only1PJ.co.uk
McJamweasel
BCF Junkie
PostPosted: 22:14 - 31 Jul 2003    Post subject: Reply with quote
Are you sure its wet with petrol? To find out try holding a match to it.
kev
I Hump Things
PostPosted: 22:23 - 31 Jul 2003    Post subject: Reply with quote
don't listen to them is a bomb, run for your life. Very Happy
20:02:36 Jammy-R6: any holes a goal
20:02:48 kev: even if its a hairy mans arse
20:02:56 Jammy-R6: hell yes
P_J
PostPosted: 22:31 - 31 Jul 2003    Post subject: Reply with quote
You know, on any normal day, id belive everything you lot told me... tonight though, i'm feeling slightly suspicious so i might give the match idea a miss.
Anally retentive, McJ, thanx mate! Thats the nicest thing anyone has said to me today Smile
Doesnt working in a call centre make you feel special and loved by all Confused
Grumpy Mother F's
I washed previously mentioned filter and there was a shed load of creamy coloured gunk came out of it.
No sperm / masterbation jokes please children. My man fat doesnt smell of petrol, and no one else has been using my bike. Smile
Only1PJ.co.uk
Lee
PostPosted: 23:35 - 31 Jul 2003    Post subject: Reply with quote
its most likely just water. In the rain (or ride through a puddle or a wet road) water gets into the airbox via the fake ram-air pipes and from the front of the bike to some extent, and the foam just absorbs it to stop water and shite getting into the fuel mixture. If you run the filter element (sponge) under a tap i bet the water comes out the other side a dirty colour, and there are usually flies & bits of gravel etc stuck on there.
And as has already been said, it smells of fuel as it is connected to the carb.
You could run without and airbox / filter, but then you are letting all sorts of shit into your engine, and it will cost you in the long run!
EDIT: the creamy coloured gunk is a spray which is sprayed onto air filter elements which absorbs water and sticks to bits of crud that get sucked into the airbox. You can buy the spray from motor factors etc, and usually you get it supplied if you buy a K&N / pipercross filter.
P_J
PostPosted: 00:07 - 01 Aug 2003    Post subject: Reply with quote
hmmm, i washed that 'gunk' out of the filter. that a bad move?
Started the engine with the filter in and the top of the box off, lifting the foam up and down whilst reving at the same time. The noise difference was quite surprising. Is this just show or will it make a difference, good or bad, to performance.
Seemed to start on first click. doesnt normaly. Obviously if the engine doesnt get the air it needs, its going to struggle.
What difference, if any, would it make to running without the filter, or changing for a different (thinner but just as effective (even home made)) filter.
Only1PJ.co.uk
cagiva gezzer
PostPosted: 00:10 - 01 Aug 2003    Post subject: Reply with quote
What did you wash it in?????
PETROL i hope!
If you were a bit thick and washed it in water, the creamy stuff is the oil emulsifying in the water.
It wouldnt be soaked in petrol as petrol will evaporate. It was soaked in air filter oil. Air filter oil is like normal oil, but very very sticky. Before you put it back in you need to re-oil it with proper airfilter oil.
Anymore questions?
cagiva gezzer
PostPosted: 00:14 - 01 Aug 2003    Post subject: Reply with quote
The fact that it starts better without the filter would suggest that your carb isnt set up right. Prob needs the idle circuit adjusted.
Removing the air filter would mean you need to re-jet the carb due to more air getting through. It would be a lot louder and your piston would be shot blasted by all the shit that gets sucked in.
You could make a thinner filter, but you would be better putting your time and effort into opening up the intake of the airbox.
P_J
PostPosted: 00:16 - 01 Aug 2003    Post subject: Reply with quote
yeah, where do i buy a new one
What difference will it make if the filter is not soaked in 'proper air-filter oil'
(Hoping not much because i am thick and washed it in water) Confused
Only1PJ.co.uk
cagiva gezzer
PostPosted: 00:24 - 01 Aug 2003    Post subject: Reply with quote
Air filter or air filer?
Anyway, air filter oil is VERY sticky, almost like hair gel.
Normal oil wont stick to the filter and wont trap the shit.
Air filters cost 10-15 quid, but generally come dry.
Best bet, soak your filter in petrol, dont wring it or scrunch it up, just press it between your palms. Take it down to your local bike shop and ask them to oil it.
Robby
Dirty Old Man
PostPosted: 00:44 - 01 Aug 2003    Post subject: Reply with quote
Or you can oil it with 80/90 gear oil. Haynes recommend that for foam filters.
P_J
PostPosted: 00:48 - 01 Aug 2003    Post subject: Reply with quote
£10 / £15 quid for a regular foam filter?
Looked at KandN page and there doesn't seem to be any bog standard ones for NSR(just had a quick look though).
Also saw on another page somewhere that the NSR airbox was taken off all together and replaced by KandN filter.
Is there any point or benefit to doing that?
Only1PJ.co.uk
cagiva gezzer
PostPosted: 00:49 - 01 Aug 2003    Post subject: Reply with quote
If youve got 80/90 gear oil sat in your garage, you are more than likely to have oil filter oil.
Wank on it?
PostPosted: 00:53 - 01 Aug 2003    Post subject: Reply with quote
Never yet seen a K&N replacement airbox element for a 2 stroke.
A single filter may give a small improvement in performance. Depends on how good the stock airbox is, and how well you insulate the k&n from warm air from the engine. It will make a fair amount of extra noise and be a pain when it gets wet
cagiva gezzer
K&N - more peak power, less every where else, more peaky, more likely to feck up in the rain or damp, loud.
K&N generally only make for 4strokes.
Lee
PostPosted: 01:10 - 01 Aug 2003    Post subject: Reply with quote
Neither have I, was just using it as an example. I remember getting cans of this stuff with K&N's and pipercross filters when i dabbled in cars Smile Although you should be able to make a standalone filter (cone) from another bike or small car fit relatively easily.
They also can cause problems with carb icing in the winter!!
Dont get me wrong, I wasnt reccomending him to get a K&N or anything here! I know that the performance increase on a 125 will be virtually nil, and will just make a rorty induction noise. The only time I would say it was a good idea is if the original airbox needed replacing, as the original part from honda is probably some £45,000 Very Happy
PostPosted: 01:21 - 01 Aug 2003    Post subject: Reply with quote
On cars yes. On bikes I don't think that is so much of a problem. Bikes are generally set up to try and pull in cool air into the airbox anyway so they will suffer from carb icing. Suspect that you might even make the problem not as bad if you don't shield the filter from the engine heat
My old FZ used to suffer from carb icing quite badly. Would drop to 25mpg and barely run below 4000rpm. Also had carb icing on the old MBX125 once. On that you could see the carb and it was so cold that frost had even formed on the outside of the carb!
Lee
PostPosted: 01:29 - 01 Aug 2003    Post subject: Reply with quote
Hehe! now that is carb icing!! lol Laughing
The last post was made 23 years, 48 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.79 - MySQL Queries: 13 - Page Size: 116.94 Kb
