PARTIAL DERESTRICTION
Scooby
Scrappy Doo
PostPosted: 21:10 - 04 May 2002    Post subject: PARTIAL DERESTRICTION Reply with quote
Hi guys,
Had a steady go at derestricting my NSR today. Its a 2001 model, Y plate. I have drilled the welds and removed the restrictor in the exhaust and binned it.
I am a little bit wary of fucking my bike up if I try and remove the intake restrictor, so I dunno whether to do it or not???
Anyway, I am at work tomorrow (sunday), so won't get a chance to go out on the bike till monday, and I was just wondering, with just a partial derestriction (the exhaust) will my bike be any faster, or will it be the same till I have derestricted both the exhaust and the intake restrictor???
Scooby
Scrappy Doo
PostPosted: 22:20 - 04 May 2002    Post subject: Reply with quote
Someone please reply!!
retrofly
PostPosted: 22:53 - 04 May 2002    Post subject: Re: PARTIAL DERESTRICTION Reply with quote
scoobysnacks wrote:
and binned it.
Heart attack!!!!!!
Made me think that you had binned the whole bike (dumb ass).
Anyway ihad a partialy de-restricted bike and nothing went wrong because of it. alot of people fully de-restrict NSR's so partially de-restricting it will not do any damage to the engine, well no more than a fully de-restriction
Luke
"The food was not undelicious"
-Homer Simpson (Exceptional beast : Underachiving Human)
www.geocities.com/retrofly
Dan
PostPosted: 23:04 - 04 May 2002    Post subject: 1 Reply with quote
have u tested it m8? go much better?
minesweeper
Whoah there!
PostPosted: 11:36 - 05 May 2002    Post subject: Reply with quote
Remove the intake the jump in performance is noticeable but overall about 5mph speed boost but so much smoother!
matt
Scooby
Scrappy Doo
PostPosted: 23:10 - 05 May 2002    Post subject: Reply with quote
Ok i got about 82mph out of it, if I remove the intake restrictor surely it will go faster than 5mph extra???
Milo
PostPosted: 23:33 - 05 May 2002    Post subject: Reply with quote
you can easily get 82 out of a fully restricted bike. you should now be hitting about 90 with no probs. i hit about 102 down a hill with just the exhaust restrictor out. it was much smoother and the full powerband was nearly unleashed. taking the intake out with make it smoother still and increase the acceleration. you should then be hitting 100 on the flat
Dan
PostPosted: 23:44 - 05 May 2002    Post subject: 1 Reply with quote
how come i can only get 90 out of mine, its quite hard to get there
Milo
PostPosted: 23:55 - 05 May 2002    Post subject: Reply with quote
Dan, is your's fully de-restricted?
90's easily obtainable on a long stretch of road. have you tried going down on the tank? (no-not trying to give it head!)
when i was doing it my elbows were up in the air. my helmet was occationally touching the bike, my neck caned and I was having to look up nearly as far as i could. that's what it's all about!
for the un-flexible out there (me!) try putting your feet on the pillion pegs.
if you've tried all that then maybe there's some welding left in the exhaust. could cause a problem with the airflow.
good luck!
Shaft drives rule. Razz
PostPosted: 19:57 - 06 May 2002    Post subject: Re: PARTIAL DERESTRICTION Reply with quote
Given how hard most people have to try to get the exhaust restrictor out, you stand less chance of screwing it up doing the inlet restrictor. You have already done the difficult part of the job
Milo
PostPosted: 18:09 - 07 May 2002    Post subject: Reply with quote
Well if you're new to taking engine's or whatever apart then the intake's the most scary one to do, but in fact the easiest.
the exhaust is easy as you can't really go wrong, and it makes the most difference to the power. 4 bolts, 3 drill bits, 1 grinding bit and 4 bolts back on. easy
The last post was made 24 years, 128 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 0.66 - MySQL Queries: 13 - Page Size: 67.17 Kb
