Can anyone help me fix my bike?
wisebeuy
PostPosted: 17:10 - 02 Aug 2003    Post subject: Can anyone help me fix my bike? Reply with quote
I have a fairly old, but good nick, aprilia 50cc, and guess what, I',m having problems Sad . I first had a problem with the HT coil, which appeared toi be knackered, as i was getting no spark and everything else was OK. So i replaced the coil, at great expense, and i now get a good spark. However, When the spark plug is fitted in the gasket, the bike refuses to start, and when i take the plug out again, it appears to have flooded as it is covered in petrol, probably causing it not to spark when fitted, i cannot see how it is flooding, the float ball seems to be working fine, please, any advice greatly appreciated.
Wise
Robby
Dirty Old Man
PostPosted: 17:29 - 02 Aug 2003    Post subject: Reply with quote
spark plug gasket? there is no spark plug gasket.
Are you testing the spark by holding the plug away from the cylinder head? because you shouldn't. Should be touching the cylinder head.
wisebeuy
PostPosted: 17:32 - 02 Aug 2003    Post subject: Reply with quote
sorry i meant when i put the spark plug back into the cylinder head. But when it is out and earthed it sparks. How do i stop it from flooding though?
TGE125NSR This post is not being displayed because the poster is banned. Unhide this post / all posts.
PostPosted: 15:52 - 03 Aug 2003    Post subject: Reply with quote
There is a good chance that you have alot of fuel floating round the engine from trying to start it.
Take the spark plug out and crank the engine over with the plug out (with the kill switch off). Watch out that if the kill switch is in the run position it will be sparking while any fuel gets pumped out of the spark plug hole.
Take the air filter out and clean it.
Tap the float bowl of the carb with the handle of a screw driver. The floats can stick and this sometimes frees them off without needing to strip the carb
wisebeuy
PostPosted: 20:37 - 03 Aug 2003    Post subject: Reply with quote
OK, now i have a problem with the spark again, it is a new ht coil, and the wires going into it seem to be working(i got shocked and all!), is there any way to test whether there is a voltage coming out of the coil? there is a connection in the lead, tested with ohmeter, but no connector in any of the three fittings that go onto the spak plug i have, is there meant to be, or is there a gap? the spark plug itself is fine, as i have tested in the lawnmower. any ideas? thanks for everyones help so far, much appreciated, but does anyone have ideas on this new issue?
Thanks, wise.
The last post was made 23 years, 51 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 0.54 - MySQL Queries: 13 - Page Size: 49.36 Kb
