| Stiffler |
 Stiffler World Chat Champion
 Posted: 10:13 - 04 Jan 2007 Post subject: Newbie Crisis - Clutch Cable Snapped |
Hello Everyone,
Sorry if this should be in Workshop, but I'm also in search of some advice. This morning on the way to work my Clutch Cable snapped. I was in the centre of Manchester and still a fair old way from where I work. I couldn't ride the bike without the clutch I've left the bike outside an office I used to work at where is should be relatively safe...
Anyway I really need to get my bike fixed but I've no idea how to go about it. I also don't have the spare parts I need. What should I do? Is there a break down service that will be able to sort my bike out?
Any suggestions welcome! My brain is very much stuck in the box at the moment and I've lost all ability for rational thought, it's all confused panic atm.
Tim ____________________ Current Bikes - Kawasaki ZX-6R (636) | BMW G650GS |
| BFG |
 BFG Brolly Dolly
 Posted: 10:36 - 04 Jan 2007 Post subject: |
A bike can be ridden without a clutch. But if you've never done it - "in traffic" is not the time to learn.
You can move the gear lever between gears without the clutch and it will change fine if you are gentle on the revs. Pulling off and stopping are the hard bits.
To pull off, sit on the bike with engine running in neutral. Paddle forward with your legs, once you are moving at walking pace, drop it into 1st - easy on the throttle.
Avoid coming to a complete stop - hang back at lights etc. There will be times when you have to, so get into second and tap down into neutral. Or, just brake and let it stall, into neutral, restart etc.
Fix:
You need a replacement clutch cable. The toolkit in the bike should be adequate to fit one to get you home. You don't need to extract the old one from under the tank right now (you'd need extra tools), you can route it on top of the engine.
A recovery service would only take you to a dealer or to home. Try calling your local dealer, they can probably pick the bike up for you and repair it. You'd probably need to be with the bike when they arrive.
Good luck!
| finpos |
 finpos World Chat Champion
 Posted: 10:38 - 04 Jan 2007 Post subject: |
Depends on a number of things;
Easiest is to get it recovered. you may have recovery as part of your insurance (e.g. standard policy from "ebike" does that). if not, ring the aa/rac, join on the spot and get the bike recovered - they'll charge you a bit more than usual for doing this.
Next, get a new cable inner and some basic tools. At worst, you'll have to take off the clutch lever so you can pull the old cable out of it's sheath and feed the new one in, then there's a couple of nuts at the other end and final adjustment. It's not too hard, if you can get the part.
Finally, ride it home. That will involve bump starting it and stalling it if you actually have to stop, but will do wonders for your anticipation because you'll be trying not to. See also clutchless gear changes
finpos. |
| st3v3 |
 st3v3 Super Spammer
 Posted: 10:48 - 04 Jan 2007 Post subject: |
first, calm down...
deep breath,
now, as your probly more focused, you should be more rational, call your nearest dealer, wo will order youyr part and could do work for you, or you could do this, depending on whether or not you mind getting your hands dirty.
then pay the bill.
Simple.
good luck.  ____________________ Roger wrote: Women don't get damp for clingy puppies. Get some better happy pills, hit the gym & buy a medallion the size of a dinner plate. Job done |
| davidimurray |
 davidimurray Nitrous Nuisance
| Gazdaman |
 Gazdaman I did a trackday!!!
| Itchy |
 Itchy Super Spammer
 Posted: 14:03 - 04 Jan 2007 Post subject: |
Stiffler , order some parts online , failing that ask Gaz at Regent (in Bury) ask his dad to make you a cable he'll do it there and then and charge you £20 for it , fitting is a piece of piss I'll do itfor you if you want. ____________________ Spain 2008France 2007Big one 2009 We all die. The goal isn't to live forever, the goal is to create something that will. In the end, your life will flash before your eyes. Make sure it is worth watching. |
| Itchy |
 Itchy Super Spammer
 Posted: 14:04 - 04 Jan 2007 Post subject: |
also On Ya Byke has lots of common cables for sale ,
clutch cables are very specific though so if they don't have one don't buy! ,
if you need a ride home , giz a call , long as you have a lid you can sit on the back.
depending on where it is and if you can kick it into Neutral , I'll even give you a tow (more like a push) home , if you push it out of the city centre I'll push you home its not particularly legal so I don't do it in CCTV infested zones.
EDIT:
if you have some pliers and or a ring spanner and some gaffer tape you can use your foot to activate and deactivate the clutch , I did this recently ____________________ Spain 2008France 2007Big one 2009 We all die. The goal isn't to live forever, the goal is to create something that will. In the end, your life will flash before your eyes. Make sure it is worth watching. |
| Stiffler |
 Posted: 23:08 - 04 Jan 2007 Post subject: |
Thanks for all the hints and tips, I managed to get it sorted. Sorry for the late reply as well.
I rang almost every single bike place in central-ish Manchester but the response to "Have you got a Clutch cable for a Yamaha YBR 124" was "a who?" or "What the heck sort of bike is that?". A couple of places did however offer to make one up if I took the old one to them and one guy took some extra time to talk me through how you go about riding a bike without the clutch.
I finally took a bus over to the Sale Yamaha Centre on my lunch and picked up the correct cable for the YBR. Fitting turned out to be a pleasant surprise, not requiring any tools at all apart from some common sense and the ability to copy the old cable. Had a quick fiddle with the tensioner and I was away! I'd prefer to be known as Bike Mechanic Extraordinaire from now on
Special thanks to Itchy for offering to rescue me! That would have been legendary.
| Ariel Badger |
 Ariel Badger Super Spammer
| Stiffler |
 Posted: 23:32 - 04 Jan 2007 Post subject: |
Thanks Ariel, while I was driving home I'd planned to ask about whether or not I would need to lube the cable. I'd totally forgot about it sat here though!
Does it matter what sort of lube I use? ____________________ Current Bikes - Kawasaki ZX-6R (636) | BMW G650GS |
| TheDonUK |
 TheDonUK World Chat Champion
| Ariel Badger |
| Rob |
 Rob World Chat Champion
 Posted: 23:46 - 04 Jan 2007 Post subject: |
My emergency rucksack contents are a can of tyre weld, a new clutch cable and a leatherman tool. Those 3 things get you out of most situations!! ____________________ Love is 1050cc  |
The last post was made 19 years, 259 days ago. Instead of replying here, would creating a new thread be more useful? |
