Can someone explain gear ratios to me?
5v3d3b0
PostPosted: 14:33 - 06 Jan 2007    Post subject: Can someone explain gear ratios to me? Reply with quote
Please can someone explain how gear ratios are calculated and what significance they have... Maybe this should be in the workshop, so sorry if that's the case.
bazza
PostPosted: 15:24 - 06 Jan 2007    Post subject: Reply with quote
It's a long shot, but it might just work...
https://www.physorg.com/newman/gfx/news/logo-Google.gif
Rolling Eyes
gavin
PostPosted: 15:26 - 06 Jan 2007    Post subject: Reply with quote
gears multiply torque. the lower the gearing, the more torque, or rather thrust, you will have at the rear wheel. accereration will be higher, top speed will be lower ( though this isnt always the case - see below)
overall gear reduction is three parts:
primary reduction ( crank shaft to gearbox) is usually quoted as driven (gearbox) over drive (crank) this might be 68/19 or 3.587
gear ratios are usually quotes as driven gear over drive gear, first might be 39/12 or 3.250, sixth might be 24/26 or 0.923 etc
final drive ( chain and sprockets) is also quoted as driven over drive, this might be 48/14 or 3.428
you can usually only alter the final drive, smaller at the front and/or bigger at the back lowers gearing, and vice verca.
this is one of my bikes on standard gearing
https://homepage.ntlworld.com/gavin.prior/dynabike/lomas/through%20gears.jpg
and this is it on lower gearing
https://homepage.ntlworld.com/gavin.prior/dynabike/lomas-opt/through%20gears.jpg
note that in this case the top two gears are redundant on standard gearing ( brown line is as fast as it can go due to drag) but lowering the gearing increases the thrust in 5th and 6th and allows it to pull slightly higher top speed, as well as accelerate better through the gears.
1988 TZR125 : 1990 RD350YPVS/ RGV250 HYBRID : 1982 RD80LC : 1983 RD80LC : 1994 RGV250 : 1991 TZR125 / CR500R HYBRID : 1976 BENELLI 500 QUATTRO : 2006 TRIUMPH 675
5v3d3b0
PostPosted: 16:48 - 06 Jan 2007    Post subject: Reply with quote
Gearbox
6 speed.
1st 10/30 (0.33)
2nd 14/29 (0.48)
3rd 17/27 (0.63)
4th 19/25 (0.76)
5th 21/24 (0.87)
6th 22/23 (0.67)
Thats's the gear ratios for the Rs 125. What can I find out looking at that. It still just looks like numbers... First gear is 0.33...Right. 0.33 WHAT?
Thanks for your patience
gavin
PostPosted: 20:09 - 06 Jan 2007    Post subject: Reply with quote
0.33 to 1 or 0.33:1.
drive gear pinion from clutch has 10 teeth, first gear cog has 30 teeth. one complete revolution of drive gear pinion = 0.33 of one full revolution of the first gear cog.
The last post was made 19 years, 163 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 1.27 - MySQL Queries: 13 - Page Size: 45.48 Kb
