NSR125R1 Flywheel Puller
stanis3of7
PostPosted: 16:38 - 06 Jan 2007    Post subject: NSR125R1 Flywheel Puller Reply with quote
Hiya all,
Well my NSR125 saga continues... barrel off and whilst piston has siezed, the barrel is clean so gonna rebuild...
So more guidance needed... after a bit of a fight the flywheel nut is off but need a puller to remove the flywheel.... unlike other bikes where the puller would screw into the flywheel on a left handed thread the NSR125R1 has an external right hand thread which tell me the puller screws over the top...! so the one in my tool box isn't much good... so
..please can anyone advise where i can acquire such a tool...without going to honda and paying mega bucks... thx
hmmmnz
PostPosted: 00:59 - 07 Jan 2007    Post subject: Reply with quote
can you post a pic??
im not familar with the nsr, but that does sound odd,
https://www.nsr250.net/marketplace/product_info.php?products_id=36
the humans are dead
I kick arse for the lord
PostPosted: 01:13 - 07 Jan 2007    Post subject: Reply with quote
You can sometimes get them with a 3-leg puller held on to the outside of the flywheel using a big jubilee clip. Just be carefull not to crack the flywheel using excessive force though.
djneu-trix
PostPosted: 01:39 - 07 Jan 2007    Post subject: Reply with quote
https://tyga-performance.com/site/index.php?cPath=71_25&osCsid=326268b250881f31849fc52334da5ccc
try there! dont know if a 150sp or 250 puller will work but u can ask!
pg
alains
PostPosted: 01:49 - 07 Jan 2007    Post subject: Reply with quote
download my file https://www.geneva-racing.com/~alains/NSRtips.doc
inside you've got a DIY tool for that
stanis3of7
PostPosted: 15:01 - 13 Jan 2007    Post subject: Reply with quote
Excellent guide but lack tools to make the diy part. Using two flat spanners and a hammer managed to remove the flywheel no problem.
So my next question - the starter ring became detatched from the flywheel at some point and the loose bolts and starter ring has ground away at the casing around the main bearing. I have cleaned all the swarf from inside but could any of the debris gotten into the inside of the crank case?... Can i simply replace the flywheel/starter ring and run the engine? any thoughts?
alains
PostPosted: 17:40 - 14 Jan 2007    Post subject: Reply with quote
yes , call TIM at DSS 01728833020 and ask for a new ring . if delay , you can still use the bike with bump start . sorry , but i am not sure if i have well understood your question . my english is not so much technical , if i was wrong try to re-ask your question in an other way
The last post was made 18 years, 347 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.36 - MySQL Queries: 13 - Page Size: 51.99 Kb
