| speed demon |
 speed demon Guest
 Posted: 09:38 - 03 May 2002 Post subject: bigger carb more speed were do i get |
8) my mate on his rs has a bigger carb on is rs 125 and its all standard apart from the carb and it f*cking batters my bike in acceleration is it possible to get a bigger carb for the nsr 34mm or higher if so were from and what changes will need to be made to accomadate this carb thanks for your answer  |
| Dan |
 Dan Brolly Dolly
| craigT19 |
 craigT19 Jolly Green Giant
 Posted: 16:05 - 03 May 2002 Post subject: .... |
mallosi do a larger carb for the nsr not shur how much it is but theres pics of in on there web site,
dont forget a standard rs will beat the nsr hands down anyway, it has a tuned engine:) but thats why they have a bad rep for reliability ____________________ Bikes owned :- 2001 nsr125, 1999 zx6r, 2006 yzf-r1, 2009 xmax 250, 2012 yzf-r1, 2015 MT-07
Current bike : - 2016 MT-10
BCF member pops. sadly missed 1945-2003 |
| Stevo |
 Stevo Guest
 Posted: 21:49 - 03 May 2002 Post subject: |
I think the Malossi kit is just a 30mm carb, but not sure.
The problems you will have with the larger carb are increased fuel consumption (the extra power doesnt come free), needing a new air filter (although you might be able to force the old airbox onto the new carb), and needing someway of opening the throttle fully. The RS uses a small round box in the throttle cable to gear up the cable (so you pull the cable 10mm, and the other end of the cable moves 12mm, or so), but this gives you a heavier throttle. Also the carb rubber (the rubber piece that the carb slots into, which bolts to the engine) will almost certainly not accept a 34mm carb. On the Aprilia it is easy as the RS was sold with a 34mm carb, so you just by the other carb rubber.
As to power, the old AF1 managed 22hp with a 28mm carb. The RS125 with a 34mm carb managed 28.5hp (PB road test figures). How much of that is due to the carb, and how much is due to improved exhaust and porting I am not sure. I would guess that about half that power difference is due to the carb.
A bigger carb will give plenty more power, and I would say all through the rev range. However, if you open the carb too far at particular revs then you will be making less power.
Keith |
| Stevo |
 Stevo Guest
 Posted: 22:05 - 03 May 2002 Post subject: |
Hi Keith yeah id agree with what you say, but id still expect low end power to fall with the bigger carb, as the airspeed would be lower through it at low revs, than the std carb. I remember reading about someone having an RG500 tuned with the target to reach the claimed crank 95bhp at the rear wheel. They tried bigger 36mm carbs, but the motor would not hold a steady load on the dyno nor accept full throttle below 5k rpm. They then found that the power increase they had found had little to do with the big carbs, but the fact that the airbox and intake ducting had been removed, and it was the increased airflow that was responsible for most of the power gained, rarther than the big carbs, which actually made the bike run worse for the most part. Having said all this, i have heard that the modern large bore flat slide carbs like those used on MX bikes (Keihin PWK/ Mikuni TMX) are very good at responding to the throttle even at low speeds, as they seem to promote a higher airspeed through the carb at all times when compared to a normal roundslide carb. |
| Ropehead |
 Ropehead Could Be A Chat Bot
 Posted: 18:15 - 04 May 2002 Post subject: Bla Bla |
A stock bike with a turbo will piss all over any bike nomatter how much u have spent on induction kits, race exhausts, new reeds BLA BLA BLA.
Just stick a turbo on ya bike. Get A HOLSET one!!
OHH but it might blow up..... well it would go shit fast before it did!!  |
| Guest |
 Guest
| Hunter |
 Hunter Nitrous Nuisance
 Posted: 17:17 - 07 Jul 2002 Post subject: |
Does anyone have any ideas about the size of the jet an RK comes with? Usually is this number etched on the jet itself?
Thanks  |
| uglykidjoe |
 uglykidjoe Nova Slayer
| Swede |
 Swede Guest
The last post was made 23 years, 173 days ago. Instead of replying here, would creating a new thread be more useful? |
