| imabikr |
 imabikr Scooby Slapper
 Posted: 07:56 - 09 Jan 2007 Post subject: Overheating Problem |
Yesterday after about 5 to 10 minutes after getting on the bike the temperature gauge shot up to 124 degrees, on came the warning light. The fan kicked in at about 101 as usual but didn’t really seem to make a difference.
I stopped the bike, checked coolant etc, all seemed fine and the engine didn’t seem that hot (glove off to feel the heat coming from it), but oddly enough the radiator was fairly cool???
Anyway, I’ve taken it to the garage for them to check it over. But was hoping someone has any idea what the cause is lightly to be? Stuck thermostat, ECU problem??
I'm hoping that its nothing too serious as I’ve only had the bike for a couple of months
btw it's a 2001 TT600 with 5500 miles on the clock. |
| Wafer_Thin_Ham |
 Wafer_Thin_Ham Super Spammer
 Posted: 09:26 - 09 Jan 2007 Post subject: |
If the fans kicked in, probably a sticky thermostat. Could also be an air lock in the system if it's been drained recently. ____________________ My Flickr |
| imabikr |
| finpos |
 finpos World Chat Champion
| imabikr |
| colin1 |
 colin1 Captain Safety
 Posted: 23:12 - 22 Jan 2007 Post subject: |
tt600's do run hot, but not usually that hot
check the oil level using the dip stick, and the level of coolant.
my tt600, is currently running a bit hot, which im a bit concerned about, and im not quite sure what to do next
mine only gets to 103 tho, and shortly after that it will cut out
if its overheating now, whats it gonna be like in the summer ?
i havnt checked for airlocks yet in the coolant tho
i did have to mess with that a while ago to refit and exhaust, so i might have an airlock.
but then a year ago, i did have to have the temperature sensor replaced after dropping it, and i have dropped it since, so i might need that again ____________________ colin1 is officially faster than god |
The last post was made 19 years, 50 days ago. Instead of replying here, would creating a new thread be more useful? |
