couple of pc probs
Jenks
PostPosted: 18:20 - 10 Jan 2007    Post subject: couple of pc probs Reply with quote
right first off, sometimes my pc will go So so so so so slow, for no reason even though it says i have 99% cpu?!
then after a couple of mins its okay...
Second, CSS... I have a 1900 athlon cpu, 756 mb ram, 6800 GS gfx card with 512 mb ram on it, exept the game runs crap. nearly all the time laggy :S - 1mb internet.
lastly every so often my pc will freeze up and when i restart, i get a Blue screen (of death) that says "Unmountable_boot_volume" and continues to do it untill ive reset it about 50 times!!!
all help apreciated!!!!
1978 MZ TS 250 1 Supa 5
1992 yamaha fzr1000 exup
1998 aprilia af1 sintesi
Silver
PostPosted: 19:41 - 10 Jan 2007    Post subject: Reply with quote
Run a decent virus/spyware checker on it and read here.
Jenks
PostPosted: 00:35 - 11 Jan 2007    Post subject: Reply with quote
chears mate, ive run virus checkers and spyware, got nothing, whats the normal PC temp??
GodzGift
PostPosted: 12:44 - 11 Jan 2007    Post subject: Reply with quote
40 degrees is a nice temp for the CPU,
- try checking for REGistry clearner
- increase virtual memory
- update graphics card drivers
- change the runtime settings, graphics of CSS reduce colour detail etc, lag is based on ur 1mb connection so upgrade to 2,
if you have done anything recently to your pc try going back and undoing it
Bike Level: Amateur | CBT Passed
Silver
PostPosted: 22:06 - 11 Jan 2007    Post subject: Reply with quote
Depends where it's measured. CPUs will take anything up to around 80 degrees C, although much lower is normal. Internal case temperature? Somewhere around 30 degrees.
Jenks
PostPosted: 23:57 - 11 Jan 2007    Post subject: Reply with quote
where do i change the runtime settings mate?
satans_BIG_helper
PostPosted: 11:25 - 12 Jan 2007    Post subject: Reply with quote
Maybe you have a piece of spyware or a app running in the background that is just munching up your computers resources. spybot S&D is a good spyware remover also run a good up to date anti virus on a full scan see if that finds any nasties but run them both in safe mode as in safe mode a lot of the spyware nasties dont load up with your system and the anti spyware software should find them easier and be able to succesfully remove them
With CSS make sure the HDR lighting is turned off in the advanced graphics settings and maybe turn some of the effects down to medium or low settings and also check the directx version that the game is using its shown in the bottom right hand corner of the graphics setting screen to try the different versions of directx to see what runs best in the console you put
mat_dxlevel 80 for dx 8
mat_dxlevel 90 for dx 9
I cant remember the other commands for the various different versions of directx as its been 6 months since i played any games
Another thing to check is your rates
in the console for CSS put the following commands
rate 20000
cl_cmdrate 80
cl_updaterate 80
if these are set overly high or low it will cause lag and stutter issues most likely is the graphics effects especially on larger servers
Failing that a FPS config might help raise your frame rate and decrease your lag
Hope this rant helps
The last post was made 19 years, 44 days ago. Instead of replying here, would creating a new thread be more useful?
Post new topic   Reply to topic    Bike Chat Forums Index -> The Geek Zone All times are GMT
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 1.18 - MySQL Queries: 13 - Page Size: 54.21 Kb
