I Have a SCSI Drive - Can I Use a SATA or IDE Aswell?
tokarev
PostPosted: 07:48 - 11 Jan 2007    Post subject: I Have a SCSI Drive - Can I Use a SATA or IDE Aswell? Reply with quote
I currently have a SCSI drive (internal) and want to add another hard drive as a slave. I was having a look online at SCSI drives but they all seem fucking expensive. Laughing
SATA and IDE drives are much cheaper. What I want to know is will I be able to plug in a SATA or IDE drive into my existing system? Or will the existing cables not fit?
Cheers.
bazza
PostPosted: 08:36 - 11 Jan 2007    Post subject: Reply with quote
Assuming you have the right connections, you should be able to add another drive without problem. Windoze requires drivers before it will recognise SATA drive though.
techierob
PostPosted: 08:42 - 11 Jan 2007    Post subject: Reply with quote
they won't fit unless you've got ide ports on the board. What type of scsi interface is it? ide-to-scsi adaptors exist, but I've never tried them myself and I've no idea how much they'd cost.
Last I checked, the second hand prices of scsi drives were pretty good. I've got a shelf full of high-voltage differential scsi drives you could have for nothing, but they weigh about 40 kilos and the combined storage is only 30 gig
T1z3R
PostPosted: 10:38 - 11 Jan 2007    Post subject: Reply with quote
best way to tell mate is to check the specification of your motherboard.
if you can post up what make and model it is then we can tell if its got IDE or SATA on board.
if it has neither then you can still add IDE or SATA drive but you would need to buy an IDE or SATA controller that plugs into a PCI slot on your motherboard.
duck my sick!
tokarev
PostPosted: 11:58 - 11 Jan 2007    Post subject: Reply with quote
Thanks for the replies guys!
The mobo is an Asus A7V133. (It is an old computer! Razz)
I have dug out the manual for the motherboard and checked the component diagram. It says that the hard drive connectors are "2 IDE connectors (UltraDMA/100/RAID 0 Support)".
So I guess an IDE drive will work with the motherboard.
T1z3R
PostPosted: 12:21 - 11 Jan 2007    Post subject: Reply with quote
yip mate sounds like it Thumbs Up
duck my sick!
satans_BIG_helper
PostPosted: 11:28 - 12 Jan 2007    Post subject: Reply with quote
When you install a IDE hard drive go into your bios and make sure that the SCSI is still enabled as the primary boot device as sometimes when you add IDE to a SCSI set up you get all kinds of problems with it
The last post was made 19 years, 42 days ago. Instead of replying here, would creating a new thread be more useful?
Post new topic   Reply to topic    Bike Chat Forums Index -> The Geek Zone All times are GMT
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 1.18 - MySQL Queries: 13 - Page Size: 50.4 Kb
