error msg my tft monitor is giving me
brettking24
PostPosted: 20:50 - 12 Jan 2007    Post subject: error msg my tft monitor is giving me Reply with quote
Hi ive just built a new pc and when i boot up to windows i get through the windows logo bit then just as it gets to desktop my monitor dislplay goes of and says "attension input not supported"
not sure if it could be the onboard gfx?my monitor is a 15" tft monitor
onboard gfx is geforce 6100.board is nforce 400
realy need help with this.
ps the monitor comes back on after it swicthes of as long as i unplug the cable from the back of the tower and plug it back in.
thanks
Kaben
PostPosted: 21:27 - 12 Jan 2007    Post subject: Reply with quote
attach an old monitor and lower the refresh rate or screen resolution.
They may be outside the limit of that particular TFT.
Its Not a Melon, Its Clearly a Lime!!
Yamaha Fazer 600Now dead, MZ 125 SM
My Deviant Art homepage https://robabloke.deviantart.com/
Davo
Davo To The Rescue!
PostPosted: 21:29 - 12 Jan 2007    Post subject: Reply with quote
All it sounds like is that the PC is trying to output a resolution/refresh rate that isn't supported by the monitor.
Boot the PC up into safe mode and set the resolution to it's lowest settings (800x600 @ 60hz), it should work then. Once that's done change the resolution to 1024x768 (and possibly 75hz).
Always test before commiting to the change as Windows gives you 15 seconds to click on the confirm button before it drops back to a working resolution.
brettking24
PostPosted: 21:42 - 12 Jan 2007    Post subject: mmm.. Reply with quote
that might be right but i was using it at the same res on my old duron 1800 and worked fine.
could it be that it cant handle my new pc or somthing like that
im using onbard gfx geforce 6100 on a gigabyte nforce mobo
cheers
lllN30lll
PostPosted: 22:43 - 12 Jan 2007    Post subject: Reply with quote
https://www.google.co.uk/search?hl=en&client=firefox-a&rls=org.mozilla:en-GB:official&hs=xwT&sa=X&oi=spell&resnum=0&ct=result&cd=1&q=attention+input+not+supported&spell=1
Turbo R1
CRF450R
Optikn3rv
PostPosted: 10:30 - 13 Jan 2007    Post subject: Reply with quote
like the guys said 60mhz-75mhz for tft's, my old crt monitor does 85mhz and better and when i stuck my tft on same error.
Max my TfT does is 75mhz
PostPosted: 10:31 - 13 Jan 2007    Post subject: Reply with quote
On windows as you're booting up, press f8 where directed (just as windows starts). Then you can choose 'vga' mode where you can change your resolution and refresh rate if that's your problem.
The last post was made 19 years, 292 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 1.29 - MySQL Queries: 13 - Page Size: 51.15 Kb
