| nick606 |
 nick606 World Chat Champion
 Posted: 15:19 - 13 Jan 2007 Post subject: water in the carb ? |
i took my bike to a garage today after it kept cutting out when i stoped (going from high rpm to low rpm). and a noticable power loss he took it off me for about an hour and did his thing for £18 (he said there was water in the carb causing it) when i got back on the bike i noticed it sounded a tad different and the idle was now almost double what it was (was 800rpm now 1500ish rpm) there is still less power than there was it tops out about 50ish. when i use to be able to get it off the clock quite easy (clock stops at 50).
tbh i though it was the fuel/air filters needing a clean. i have also found out that my bike was running on res all the time and is now in the on position. but when i turned it back on res it sounded like more it did before i gave it to him........
how does water get in the carb and does this sound right because it seem he has just ajusted idle screw to me and turned the fuel tap to on (keep reading/hearing storys of dodge mechanics) . any ideas.
im sure its just me being paranoid he seemed like a nice fellow
nick
he also disconnected my neons (came with the bike) |
| Dischord |
 Dischord World Chat Champion
 Posted: 17:40 - 13 Jan 2007 Post subject: |
This is why I like to work on my own vehicles where I can. Unless you watch the mechanic you can never be sure what they've done to your bike/car,
Sounds like your on a moped or scooter, do you have a powerfilter on there? or is it the stock airbox? powerfilters suck up water easily and then it goes straight through the carb and into the cylinder causing misfires etc on a 8 mile trip my bike would cut out about 5miles in EVERYTIME in the wet with a powerfilter.
Things should be ok when its left to dry though.
Power loss and cutting out could be alot of things. Some people say the engine sounds different when the piston rings are nackered. ____________________ 2012 KTM EXC 250
Check out my vids - https://www.youtube.com/user/KTMSparky/videos |
 Posted: 17:47 - 13 Jan 2007 Post subject: |
If he was going to rip you off I think it would be for more than £18. I'm surprised that anyone has such a low minimum-charge nowadays.
Water can get in the tank from the fuel pump or from filling up from a can etc that had a bit of water in the bottom.
800rpm sounds a bit low for tickover on a small-capacity bike, have you checked what it should be? ____________________ a.k.a 'Geri'
| john2 |
 john2 Brolly Dolly
| nick606 |
| john2 |
 john2 Brolly Dolly
| nick606 |
| nick606 |
| john2 |
 john2 Brolly Dolly
| john2 |
 john2 Brolly Dolly
| nick606 |
| nick606 |
| john2 |
 john2 Brolly Dolly
| nick606 |
 Posted: 18:51 - 13 Jan 2007 Post subject: |
when i mean disconnect he didnt take them off just not rewire them back up (just edited the post above ) i guess i should work on my phasing of stuff as some of my posts can me misleading
nick |
| john2 |
 john2 Brolly Dolly
| sagiliam |
 sagiliam Could Be A Chat Bot
| john2 |
 john2 Brolly Dolly
| nick606 |
| Finglonga |
 Finglonga World Chat Champion
| john2 |
 john2 Brolly Dolly
| sagiliam |
| nick606 |
| john2 |
 john2 Brolly Dolly
| john2 |
 john2 Brolly Dolly
The last post was made 18 years, 343 days ago. Instead of replying here, would creating a new thread be more useful? |
