2 Stroke Compression
Dillingsuk
PostPosted: 21:28 - 13 Jan 2007    Post subject: 2 Stroke Compression Reply with quote
Got the motor back together today ready for fitting into the frame, when kicking the engine over there isn't much compression. Is this normal for "dry" barrel thats just been put back together? Im hopeing this will improve when the engine is drawing in its air/fuel mixture?
hazza
PostPosted: 21:49 - 13 Jan 2007    Post subject: Reply with quote
you do have the spark plug in right?
Dillingsuk
PostPosted: 22:00 - 13 Jan 2007    Post subject: Reply with quote
Havent got the plug in yet, just had my finger over the hole! But can hear the air passing the rings, but the barrel is "dry" (no oil) hopeing this will improce when "wet"?
hazza
PostPosted: 22:31 - 13 Jan 2007    Post subject: Reply with quote
lol how do you expect compression with a big hole in the top of the head Laughing
it should be fine mate whack the plug in if your not sure, the air you hear is the air escaping past your finger because its not a proper seal, try it and im pretty sure you will feel the different, if not the base gasket probably isnt seated right
0ddball
PostPosted: 22:49 - 13 Jan 2007    Post subject: Reply with quote
The small ones don't have much compression anyway, you can start most 2 strokes by hand. Once you get some oil in the barrel and the rings bed in it will improve slightly.
You haven't done something silly like fitting a standard size piston in an oversize bore have you?
john2
PostPosted: 22:59 - 13 Jan 2007    Post subject: Reply with quote
Get some oil in it, then see the difference.
Dillingsuk
PostPosted: 23:01 - 13 Jan 2007    Post subject: Reply with quote
Standard barrel, standard rings, its prob me just over-reacting theres only one way to find out! If it starts ill be happy if not well......................... Crying or Very sad
john2
PostPosted: 23:05 - 13 Jan 2007    Post subject: Reply with quote
If you dont mind wasting time in having to take it out again, then i would just fit it all up and then fire it up.
J.K.R
PostPosted: 19:49 - 14 Jan 2007    Post subject: Reply with quote
Get a compression tester on it!
www.oldskoolsuzuki.info
The last post was made 18 years, 347 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.89 - MySQL Queries: 13 - Page Size: 58.2 Kb
