argh i changed me brake pads and they now feel spongey
spakmitten
PostPosted: 00:23 - 14 Jan 2007    Post subject: argh i changed me brake pads and they now feel spongey Reply with quote
first time ive done them myself
so i took the rear off changed the pads, put it all together in the reverse order of taking apart and tried them out
first couple of presses were really loose as i expected because the pads need to get in close to the disc but now it seams like im pressing real hard to make the rear wheel lock compared to the old pads
anyways is this just because they need to bed in or have I mess up TO THE MAX
sanchezz_182
PostPosted: 01:10 - 14 Jan 2007    Post subject: Reply with quote
need to bed in, give it a few days, if it stil isnt fixxed bleed the brakes.... if it stil isnt fixxed, ur fucked.
no sig, thats gay!!
wilbur
PostPosted: 01:14 - 14 Jan 2007    Post subject: Reply with quote
Hmm odd advice. Sounds like you did not bleed them properly.
MattEMulsion
PostPosted: 10:20 - 14 Jan 2007    Post subject: Reply with quote
If you haven't touched the fluid, then it is probably only a case of them needing to bed the pads in. Give the pads a week to wear to the same shape as your disc as presumably this is the old one and will have some wear on it.
Yamaha YZF-R6
doggone
PostPosted: 11:27 - 14 Jan 2007    Post subject: Reply with quote
They should feel firm and very 'keen'
There must be some air in the system.
Being a back brake you might leave it a little while to see if it improves, not really a big deal to bleed them.
Slacken bleed screw on caliper block and gently pump them - have ample spare fluid to top up reservoir.
When no more bubbles come through, tighten bleed screw.
Aikman666
PostPosted: 12:40 - 14 Jan 2007    Post subject: Reply with quote
Yeah definetly sounds like theres air in the system. If its the first time youve bled brakes it will drive you mad, but you get a knack for it eventually Thumbs Up
Will work for petrol
My Design Blog
Finglonga
PostPosted: 18:19 - 14 Jan 2007    Post subject: Reply with quote
How far back did you push the pistons and how fast?
If done correctly you don't need to bleed the brakes when changing pads.
They will need bedding in to get to their full potential.
You havn't contaminated the disc with anything have you oil/WD40?
Andy Sez....
F.Y.Y.F.F.
The last post was made 19 years, 175 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 2.12 - MySQL Queries: 13 - Page Size: 51.52 Kb
