Snapped a bolt....repair help
Silky
PostPosted: 00:38 - 15 Jan 2007    Post subject: Snapped a bolt....repair help Reply with quote
Hi all. Im rather miffed....
Was changing my oil filter on my bandit 400 and i overtightened one of the bolts holding on the cover which caused it to snap.
I have no idea how im gonna fix it. Any ideas?
Cheers! Thumbs Up
Have ya ever drunk Baileys from a shoe? IM OLD GREGG!!!
veeeffarr
PostPosted: 00:40 - 15 Jan 2007    Post subject: Reply with quote
The cover to the oil filter?
If so,
No big deal, dont panic.
Take the cover off and see how much bolt you have remaining.
If there's an ample amount thread 2 nuts onto the bolt, and tighten them together.
Unscrew the remainder of the stud with the nut you threaded on first (the bottom one)
Order a new stud, then just screw that into the engine block and replace filter cover as normal.
veeeffarr
PostPosted: 11:28 - 15 Jan 2007    Post subject: Reply with quote
Nice one for quoting peep show in the Signature too! That's one of my faves Very Happy
Finglonga
PostPosted: 13:05 - 15 Jan 2007    Post subject: Reply with quote
If so,
Or you could get your oil changed at a garage next time to save hassle......Maby not. Mr. Green
Andy Sez....
F.Y.Y.F.F.
Silky
PostPosted: 13:08 - 15 Jan 2007    Post subject: Reply with quote
The studs are removable?
I thought they were welded to engine somehow?
If your right, where could i get hold of them? keep in mind my bike is an import.
veeeffarr
PostPosted: 14:11 - 15 Jan 2007    Post subject: Reply with quote
Yeah they're removable, they tiny little studs that screw into the engine casing.
As I said, thread 2 nuts on them and use the bottom nut to turn it out.
I got my replacement ones from sparesdirect, you might be luck and it might be the same as a GS500E stud as the filter arrangement sounds similar.
Fingalonga: piss off Razz
veeeffarr
PostPosted: 14:14 - 15 Jan 2007    Post subject: Reply with quote
Oh I have a spare one lying around someone I can post in an envelope to you for you to try? Only thing I ask is if it doesn't work can ya please post it back as it's always handy to have a spare!
T
The last post was made 18 years, 344 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.51 - MySQL Queries: 13 - Page Size: 61.85 Kb
