| befdelta7 |
 befdelta7 Brolly Dolly
 Posted: 00:05 - 16 Jan 2007 Post subject: fitting chain and sprocket kit UPDATE + *temp gauge question |
hi people,
are there any tips for fitting a new chain and sprockets:
any easy ways of doing it?
any particular part needed to be fitted first?
any run in period?
any things to watch out for when fitting or when fitted and taking the bike out for the first time?
thanx for your info and replys  ____________________ Dont do a wheelie in front of a traffic copper... it gets you 3pts and £220 fine.
| G |
 G The Voice of Reason
| befdelta7 |
 Posted: 01:14 - 16 Jan 2007 Post subject: |
cheers for that 'G'
iv got a split link on my chain now, like you get on old push bike and the chain im told il be reciving with the sprocket has a split link too.
is this ok, or should i be worried? its only a 125cc engine.
cheers for your reply  ____________________ Dont do a wheelie in front of a traffic copper... it gets you 3pts and £220 fine. |
| Paddy Blake |
 Paddy Blake World Chat Champion
| G |
| befdelta7 |
 Posted: 12:32 - 16 Jan 2007 Post subject: |
thanx for your replys boys!
im getting my chain and sprockets form rob sturgess at mitomondo.
iv herd quite a bit about him and his shop(good things of course) so i think i can trust him to supply the right bits for me.
one more question about the front sprocket:
is it a left hand thread or is it normal like any other nut/bolt?
one more question about the new chain:
will i have to grease it because its new or will it be already greased?
cheers for you help and replys  ____________________ Dont do a wheelie in front of a traffic copper... it gets you 3pts and £220 fine. |
| Minty |
 Minty World Chat Champion
| befdelta7 |
 Posted: 15:14 - 16 Jan 2007 Post subject: |
thank you very much for that r1NSR
thank you all who replyed too!!
| beatnck |
 beatnck Could Be A Chat Bot
 Posted: 21:41 - 16 Jan 2007 Post subject: |
yep, as said a splitlink will be fine on a 125. i recently changed the chain and sprockets on my rs, and it was quite easy! the only bitch was getting the splitlink together, but a bit of brute force with the vicegrips soon sorted that  |
| befdelta7 |
 Posted: 08:49 - 17 Jan 2007 Post subject: |
yer when i took the engine out for a clean and inspection/slight rebuild getting the split like back together on the old chain was a C U Next Tuesday
hopefully this one all goes well
cheers beatnck and everyone else who replyed  ____________________ Dont do a wheelie in front of a traffic copper... it gets you 3pts and £220 fine. |
| befdelta7 |
 Posted: 17:56 - 24 Jan 2007 Post subject: |
took the bike out just now and its horrible to ride now the diffrent sprockets are on it. probably because i need to get use to it
now 13 tooth front -- 44 tooth rear.
was 15 tooth front -- 43 tooth rear
on the pull off it wheelies(not too bad but for the first time it was a bit of a ) and it flies through the gears like no ones buisness which is what i wanted but didnt think ill be changine that fast also gets to 50mph according to the speedo in about 4 seconds which isnt bad
also
my temp gauge was reading at 47*C yesterday when i was riding it for about 40mins and on the 15min ride just now it didnt even move off 40*C (which is where the needle rests when the ignition is off) does anyone think this is a fault or is it the cold weather? bearing in mind that it was snowing earlier this morning and the right radiator as you sit on the bike was slightly warm when i got off the bike and the temp gauge was on the resting needle at 40*C(radiator that the coolant goes into from the cyclinder head) ____________________ Dont do a wheelie in front of a traffic copper... it gets you 3pts and £220 fine. |
| cagiva gezzer |
 cagiva gezzer World Chat Champion
| befdelta7 |
| cagiva gezzer |
 Posted: 20:26 - 24 Jan 2007 Post subject: |
14 / 41
£80 delivered for a full IRIS/Renthal/JT kit.
Tops out at an indicated 95MPH and pulls like THIS.
But it's a six speed box, so the internal ratios are different.
FYI
14 / 42 is the std gearing on the 6speed.
13 / 42 is the std gearing on the 7 speed. (i think) ____________________ "because one stroke isnt enough and four strokes waste two" |
| befdelta7 |
| Jebus |
 Jebus Brolly Dolly
 Posted: 21:27 - 24 Jan 2007 Post subject: |
FYI is For Your Information, and it wont matter really what part of the rad you tape up just tape it up. done the same on my dt. ____________________ 2nd time around CBT: 8/9/11
125 Varadero |
| Teaman |
 Teaman World Chat Champion
| befdelta7 |
 Posted: 01:54 - 25 Jan 2007 Post subject: |
i undid the front sprocket with a socket and very very little force was like it was hand tight. did it up tight thoe and put some glue stuff you mix up over the split like to secure it and so's to put my mide at rest of it flying off  ____________________ Dont do a wheelie in front of a traffic copper... it gets you 3pts and £220 fine. |
| bish777 |
 bish777 World Chat Champion
There is a gap of 201 days between these two posts... |
| mod661 |
 mod661 Nitrous Nuisance
The last post was made 19 years, 11 days ago. Instead of replying here, would creating a new thread be more useful? |
