carb internals
Welshd1k
PostPosted: 20:02 - 16 Jan 2007    Post subject: carb internals Reply with quote
well im starting to make a tidy carb out of my 3 spare carbs for my ns125
bought a brand new valve slide thingy of honda (£10)
and looking for jets no one locall sells them where do i get them???
then the next big question the floats
2 of the carbs have a whiteish plasticy float setup and the other has a black one with metal frame whats the diffrence preformance???
then what jets do i need and can new needles be bought?
cagiva gezzer
PostPosted: 20:07 - 16 Jan 2007    Post subject: Reply with quote
www.dellorto.co.uk
Welshd1k
PostPosted: 20:09 - 16 Jan 2007    Post subject: Reply with quote
thats helpfull Rolling Eyes
i was askign what size jets i needed now mine is derestricted ....
Timmeh
PostPosted: 23:40 - 16 Jan 2007    Post subject: Reply with quote
standard factory jets are OK if all you've done is remove the brass plate and bung inside the silencer. With the fuelling correct you'll easily get 25bhp.
PostPosted: 23:50 - 16 Jan 2007    Post subject: Reply with quote
NS stock exhaust is pretty awful. Difficult to derestrict (although works well when done). However you would be lucky to break a true 20hp from an NS.
Jetting wise, no real answer. Get a couple of main jets, going up a over a few sizes and play.
Marci
PostPosted: 10:39 - 17 Jan 2007    Post subject: Reply with quote
Nothing at all...
Jets - learn how to do plugchops, that tells you whether your current jet is too big or too small. If it says it's too small, buy a few jets that cover a range of sizes bigger and vice versa, then, again, use plugchops to work out which jet is the right one FOR YOU.
Jetting is never a clearcut "you must use this" unless the bike is completely stock, in which case you use the jets listed in the owners manual / workshop manual. Any changes from stock, and you have to work it out for yourself.
The link you were given supplies ALL parts for DellOrto carbs - needles, jets, valves, floats etc etc.
Have a search for NS125R-K - there are many threads going back in time that cover jetting with various pipes etc that you can use as a GUIDELINE BALLPARK of roughly what sizes to expect, but these won't be precise for your bike, so you'll still have to get a few sizes either side of that and try n' test.
FAB-Racing MiniMotoSidecars - Back with a vengeance - F1 Class 2011...
CBR170 engine, custom chassis - www.minimotoscene.co.uk
cagiva gezzer
PostPosted: 17:31 - 17 Jan 2007    Post subject: Re: carb internals Reply with quote
ns125rk90 wrote:
well im starting to make a tidy carb out of my and looking for jets no one locall sells them where do i get them???
www.dellorto.co.uk
thats helpfull
Rolling Eyes
Jetting depends on the bike. As said, stick in std jets as per the manual and then plug chop it or dyno it to get the best combination.
The last post was made 19 years, 41 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 1.41 - MySQL Queries: 13 - Page Size: 54.18 Kb
