| THCi |
 THCi Nearly there...
| THCi |
| finpos |
 finpos World Chat Champion
| hmmmnz |
 hmmmnz Super Spammer
| THCi |
| THCi |
 Posted: 21:28 - 16 Jan 2007 Post subject: |
Now if im reading the wiring diagram the extra pins on the flasher relay is the pulse gen. Is this what I want/need to replace with the motrax relay?
All kinda confused with this.  ____________________ Past: GZ 125 K4 Marauder, VL 125 LC Intruder, FZS 600 Fazer. Present: GSF 600 N K3 Bandit, GSX-R 600 X(soon)
"We're not gonna die. We can't die, Bendis. You know why? Because we are so...very...pretty. We are just too pretty for God to let us die." |
| finpos |
| THCi |
 Posted: 21:42 - 16 Jan 2007 Post subject: |
There is no other relay in the area. Had both the side panels off, the rear plastics are off anyway-and cant find a 2 wire one at all. Acording to my Haynes that relay is the one I want.
But after doing a google for FE249JR I get all kinds of results ranging from indicator relay, fuel pump relay for a TLR1000 and more.  ____________________ Past: GZ 125 K4 Marauder, VL 125 LC Intruder, FZS 600 Fazer. Present: GSF 600 N K3 Bandit, GSX-R 600 X(soon)
| finpos |
| stinkwheel |
| stinkwheel |
 Posted: 21:59 - 16 Jan 2007 Post subject: |
Hah. I found one on the net using ther part number 066500-4230 in google.
The Suzuki part number is 38610-03F00, it is the indicator relay and it costs... wait for it ... are you sitting down? ... £55.20!
I suggest you get yourself down to the car shop and have a rake around!
https://www.robinsonsfoundry.co.uk/shop/index.php/parts/18/818/index.html |
| THCi |
Could it be from k2 onwards bandits had hazard lights, instead of a head light switch on the handle bars?
As for the Light blue and brown they do indeed go into that relay.
https://personal.open-theweb.net/bandit/relay.jpg
Oh, ffs im an idiot sometimes-the reason im attempting to replace the relay is because its making my new LED indicators flash too quick. Sorry for leaving that out at the start-moron.
Also, the indicators come with resistors-tried them but they dont actually seem to do anything at all. The flash rate doesnt slow down at all. ____________________ Past: GZ 125 K4 Marauder, VL 125 LC Intruder, FZS 600 Fazer. Present: GSF 600 N K3 Bandit, GSX-R 600 X(soon)
| finpos |
 Posted: 22:07 - 16 Jan 2007 Post subject: |
Right, so you have a car-style flasher unit in there - and it also looks like the wiring diagram you posted isn't actually the right one because it shows the bike using a standard, bike-style two wire flasher unit.
If you want to put the motrax unit in there, you are going to have to do the reverse of what stinkwheel does and replace the car-style unit with the bike-style unit. That should be possible, however, I suspect there's very little danger of you being able to do that unless you track down the correct wiring diagram.
LED indicators - who needs 'em
finpos. |
| finpos |
| THCi |
| THCi |
| finpos |
 Posted: 22:28 - 16 Jan 2007 Post subject: |
I really can't see the two things being connected in any way, so I suspect you've inadvertently done something else. Kill switch?
If that's not the case, find the right wiring diagram for your bike and post it here - it should be pretty easy to sort out.
finpos. |
| stinkwheel |
| finpos |
| finpos |
 Posted: 23:16 - 16 Jan 2007 Post subject: |
Right, sussed it...
You're neutral light has stopped working as well, hasn't it?
I reckon your best bet will be to leave the existing, standard relay in place, but see if you can disconnect the brown and lightblue wires from the back of the relay connector. You may be able to pull the connectors out of the socket, or you may have to cut the wires.
Once you've done that, plumb those two wires to the motrax unit.
If you look on your wiring diagram, in the fuse box there are three blocks - Flasher relay, Sidestand Relay and Diode(for the neutral light). In fact, all three of those things are in the 7-pin "unit" you pulled out. So, 'tis neither a bike flasher, or a car flasher (which is what I thought originally), but some kind of "multi function unit", with 82p worth of components in it, which is sold for 55 quid.
finpos.
| THCi |
 Posted: 23:27 - 16 Jan 2007 Post subject: |
Thats what I've done. The blue & brown wouldnt pull out, so I ended up having to cut them. Will be a right mess for anybody who wants to return it to standard. I was having to strip wires in a space that fit my hands and little more.
Ah well, sorted now. Thanks for your help.  ____________________ Past: GZ 125 K4 Marauder, VL 125 LC Intruder, FZS 600 Fazer. Present: GSF 600 N K3 Bandit, GSX-R 600 X(soon)
| finpos |
| THCi |
| finpos |
| THCi |
 Posted: 15:13 - 21 Jan 2007 Post subject: |
Just checked, and it is the front sidelight as well as taillight.  ____________________ Past: GZ 125 K4 Marauder, VL 125 LC Intruder, FZS 600 Fazer. Present: GSF 600 N K3 Bandit, GSX-R 600 X(soon)
The last post was made 19 years, 205 days ago. Instead of replying here, would creating a new thread be more useful? |
