| fire |
 fire World Chat Champion
 Posted: 23:57 - 17 Jan 2007 Post subject: Powerballs |
Recently ordered one after stumbling across it..googled it and an amazin amount of results came up!
thought..wow...this has rly gota be sumin
my question is.... anyone use em? how effective are they for building muscular strength in your arms?
im not expectin amazin results.... but i sit in the office with F*ck all to do most the time...could keep me occuiped..what better than an inconspicuos workout
im one of these guys with scrawny wrists... for instance i like got a watch for xmas...put it on... then realise i need to get 3 links taken outa it!
probly get it by friday...but curiosity has gotten the better of me..wanted sum opnions off you guys...... ____________________ Write off! Honda NSR150 RR ('01) - Sold Cagiva Mito Evolution ('00) - Sold Honda NSR125 ('01) - Current Gasgas TXT 250 ('98) - Sold Kawasaki Z750 ('10) - Write off! Yamaha FZ1 ('09) - Current Ducati Streetfighter 848 ('14) |
| WR450_geezer |
 WR450_geezer Nobody likes me
 Posted: 00:03 - 18 Jan 2007 Post subject: |
Awesome things
Its quite impossible to describe the feeling of them once you get them up to near full revs and keep it going, its so smooth but so powerful and feels like if you let go the ball would fly through your living room wall.
Not too sure on building muscle but I know they help with joint pain etc, also believe they are signitured by boxers and weight lifters.
WR ____________________ Siggi, ''Fack, having Daz around is like living next door to PC-World, with a hole in the wall.'' |
| _Will_ |
 _Will_ World Chat Champion
 Posted: 00:24 - 18 Jan 2007 Post subject: |
| DanceLikeAMon... |
 DanceLikeAMon... World Chat Champion
| Dazbo666 |
 Dazbo666 World Chat Champion
 Posted: 09:24 - 18 Jan 2007 Post subject: |
I tend to find other ways of building muscles in my arms...
not too sure it would be considered inconspicuous in an office though  ____________________ 1st bike (Sept'06 - May'10) : 1991 GPZ500S / Current bike (since Nov 2009) : 2003 Suzuki Bandit 600N
Word of the day : DILLIGAF |
| TomR6 |
 TomR6 World Chat Champion
 Posted: 12:18 - 18 Jan 2007 Post subject: |
Yeah I've got one, they are really good, especially with the LCD display, trying to beat your fastest scores.
It has built my arms pretty well over the last fortnight ____________________ 2005 Yamaha R6 |
| JBurrows88 |
 JBurrows88 World Chat Champion
 Posted: 13:07 - 18 Jan 2007 Post subject: |
I dont need weights at work, just trying to lift the 20kg trays of cold meat is enough! lol
What are these powerballs, how do they work??  ____________________ Dave
XJR400 Kenney Roberts Paint Job |
| WR450_geezer |
 Posted: 13:23 - 18 Jan 2007 Post subject: |
Classic Powerball
Designed to improve the wrist muscles, simply set the inner section spinning, rhythmic circular hand and wrist movements not only maintain the rotation, but also make it steadily faster. Increased in centrifugal forces make it harder to keep hold adding resistance to your wrist thus making you stronger.
Not only is this a great exercise for your wrist, it is also extremely addictive as it incorporates a high score system.
The perfect instrument to gently rehabilitate lower forearm and wrist joints affected by carpal tunnel syndrome, repetitive strain injury, arthritis & previous breakage.
Metal powerball
Ironpower is the definitive sports instrument for athletes and enthusiasts of many different kinds of sports. It is a revolutionary new fitness product to either tone or help build substantial power and strength in hands, wrists, forearms and shoulders. It is made with extreme precision to produce a wrist ball that is smoother and faster than any other on the market!
Powerball is a dynamic and completely revolutionary new gyroscope that literally explodes with mind numbing torque and inertia once you activate its internal rotor.
It's about the same size as a tennis ball and weighs just a little more, but take a ForceOne in your hand, set that rotor in motion with the cord provided (or use your finger when you get used to it) and you'll experience an extraordinary sensation:
ForceOne slowly comes alive with gyroscopic force - a sublime yet pleasant resistance to your movement which is transmitted directly into your wrist and arms and which provides soothing, non impact rehabilitation at these lower speeds.
The innovative design of Ironpower is perfect in form and reflects the unlimited force of the core. CNC lathe work of aluminium housing and rotor is a guarantee for highest precision and perfect balance.
The hard-coat anodized surface in silver-metallic or black allows for a safe grip for high performance workouts. Due to the innovative technique of joining upper and lower part by metric fine thread. Ironpower can be opened in no time at all in order to exchange the rotor or for cleaning purposes.
The principle of IronPower
A gyroscope is a solid object that is designed to spin around a central axis. The ends of the axle rest on bearings in a steel ring, or gimbal. Start the top spinning and as long as it continues to spin rapidly, the top will remain balanced on its pointed end.
More important, the direction of the top's spin axis will resist any attempt to change the direction of the axis about which the rotor turns. This basic property results from the top's strong Angular Momentum. The rigidity in space of a gyroscope is a consequence of Newton's first law of motion which states that a body at rest tends to continue in its state of rest or uniform motion unless subject to outside forces. Thus, the wheel of a gyroscope, when started spinning, tends to continue to rotate in the same plane about the same axis in space...
When a force (your hand) is applied to a gyroscope it tends to change the direction of the axis of rotation, the axis will move in a direction at right angles to the direction in which the force is applied.
Inside the Powerball there is a rotor of about 150 or 280 gram - depending on your model - which is being accelerated by a round movement of the hand. The rotor can perform as many as 16.000 rpm (revolutions per minute) and thus generate a force of about 75 times the weight of the rotor.[/b] ____________________ Siggi, ''Fack, having Daz around is like living next door to PC-World, with a hole in the wall.'' |
| fire |
| Kaben |
 Kaben World Chat Champion
 Posted: 17:35 - 18 Jan 2007 Post subject: |
I have a normal powerball and use it regularly for physio purposes on my shoulder.
Its great, and you can really feel the strain in your forearms. Shoulder movement/work out is less obvious however.
I dont understand why that metal powerball would work more muscles groups/ areas than the plastic one? its exacty the same apart fom being metal and slightely heavier?
Can someone please explain or is this a marketing ploy to make you spend more on the metal version. ____________________ Its Not a Melon, Its Clearly a Lime!!
Yamaha Fazer 600Now dead, MZ 125 SM
My Deviant Art homepage https://robabloke.deviantart.com/ |
| feef |
 feef Energiser Bunny
| fire |
| WR450_geezer |
| VTR SP1 |
 VTR SP1 Brolly Dolly
| fire |
| Finglonga |
 Finglonga World Chat Champion
| TheShaggyDA |
 TheShaggyDA Repost Police
| fire |
| Finglonga |
| Drew |
 Drew Banned
| Jenks |
 Jenks World Chat Champion
| byke95 |
 byke95 World Chat Champion
| LustyLew |
 LustyLew World Chat Champion
 Posted: 09:02 - 19 Jan 2007 Post subject: |
Anyone know where you can get these from? Any shops that you know sell them?
Cheers! ____________________ Like a Yorkie - I'm not for the girls  |
| G |
 G The Voice of Reason
| LustyLew |
 Posted: 11:40 - 19 Jan 2007 Post subject: |
D'oh, sorry. I meant high street type shops.
I really must be more specific with my posts! ____________________ Like a Yorkie - I'm not for the girls  |
The last post was made 19 years, 33 days ago. Instead of replying here, would creating a new thread be more useful? |
