| pranaferox |
 pranaferox Derestricted Danger
| Welshd1k |
 Welshd1k World Chat Champion
| pranaferox |
| finpos |
 finpos World Chat Champion
| Mr.Everready |
 Mr.Everready World Chat Champion
| pranaferox |
| finpos |
| Mr.Everready |
| pranaferox |
| finpos |
 Posted: 19:30 - 18 Jan 2007 Post subject: |
Ok, so far, so good.
I think Mr. Everready has touched on the possible solution, You need to match the Wattage of the bulbs in the circuit to the relay (1W to 30W).
Your LED indicators are rated at 1W but I'm kinda suspecting that is just a nominal value, and they use a lot less. So two added together is less than 1W, which is too low.
With Resistors on each of the indicators, you are probably at something like 44W. Too much.
So, in short, with no futher beating around the bush, try using only one pair of the resistors you were supplied with, e.g. fit one to the front indicator but not the back on each side. That should give you about 22W - just right.
finpos. |
| pranaferox |
| finpos |
 Posted: 20:43 - 18 Jan 2007 Post subject: |
Hmm, that's interesting.
Now, I haven't got a clue what's going on.
finpos. |
| finpos |
| pranaferox |
| metallninja |
 metallninja Two Stroke Sniffer
| Finglonga |
 Finglonga World Chat Champion
| finpos |
 Posted: 14:39 - 19 Jan 2007 Post subject: |
Lo Again,
I found a wiring diagram for an rs125, which I'm assuming is much the same as your bike.
It does indeed have the weird crap I refered to going on with the repeater warning light. So, my prediction is that if you remove the repeater bulb, your indicators will start working (with zero or two resistors, not sure about four).
While you are trying to pull the bulb out have a look if the two wires going to it are red and light blue (Azure if you want to be Italian about it ).
Now, if you want your repeater to work as well as your indicators, you are going to need two 12V Diodes and a length of wire. Plus butchery to the max.
finpos. |
| pranaferox |
| finpos |
| befdelta7 |
 befdelta7 Brolly Dolly
| finpos |
| pranaferox |
| gixxersixx |
 gixxersixx Trackday Trickster
 Posted: 22:33 - 19 Jan 2007 Post subject: |
There is something causing a problem with the relay, normal problem with fitting LED's is they flash too fast due to not enough resistance. If the resistance is too high this would have the opposite effect and they would come on without flashing as in your problem. ____________________ We're all just born to die. So lets have some fun
gsxr6k1,pc,k&n,skimmed block,flowed head,yoshi gasket,cams,blue print,arrow system titanium can,quick shifter,gilles rear sets,ktech forks,ohlins shock,galfer waveys, -3front+4rear + other goodies |
| pranaferox |
| finpos |
The last post was made 19 years, 271 days ago. Instead of replying here, would creating a new thread be more useful? |
