| djneu-trix |
 djneu-trix Spanner Monkey
 Posted: 21:16 - 18 Jan 2007 Post subject: JETTING??? help me please!!! |
Hi all
i just got my beast up and running at long last! done everything by the book and its all good! tons of copresion etc!
anyway it starts and idles revs too! but a soon as you get on it it judders and only goes about 5mph then it will cut out!
i got a ns125r-k and its now got the 170cc mallossi bb kit on it and bigger sprocket and all new jets/sliders and pin!
the kit came with 2 main jets! ive tryed both of them and the same happens with both i was wondering maybe it could be the small 1 or the giant 1 that goes down the middle???? i aint got a clue! im a complete novice!
i did a plug check after idle'ing it for 10 mins and the plug was just wet with a lil bit of black stuff on it! looked good to me! going by the hanes manual! so i dont think its oil bogging it down!
i thought it might be because i put quite a bit of oil on the piston when i rebuilt it but its been idle'ing for about 25 mins all together so i would have thought it would have burt that all off by now!??
im really suprised the bike started starght away after 3 kicks! (THANK GOD)
any help what so ever is really apreciated! i got to get it working by tomorrow night!
THANKYOU!!!!  ____________________ pg |
| djneu-trix |
 Posted: 21:25 - 18 Jan 2007 Post subject: |
right thanks i will try that tomoz!
if it aint that is there anything else you can think of as i can do it all in 1 hit then and dont have to wiat for some 1 to reply!!!
THANKYOU soooooo much for ya help!!!! if i could send beer over the internet i would be sending you 1 now  ____________________ pg |
| djneu-trix |
| djneu-trix |
| djneu-trix |
 Posted: 22:27 - 19 Jan 2007 Post subject: |
Idle mixture screw either makes it ricjer or leaner, depending on which model of PHBH carb it is. For a start set it as specified in the manual (screw it fully in lightly, then back out that number of turns).
The idle speed adjuster is pretty much suck it and see. Has the same effect as holding the throttle open a tiny amount. Sounds like it is too far out if it instantly revved up to 5000.
| djneu-trix |
 Posted: 22:54 - 19 Jan 2007 Post subject: |
DO NOT screw the idle speed screw all the way in and then out one turn. The further in it is the higher the idle speed. One turn out would put the idle revs through the roof.
Main jet only affects high throttle openings. Would doubt you had the throttle open enough for the main jet to be in play when you first had a problem.
Set the idle mixture screw to stock, and play with the needle jet.
| djneu-trix |
 Posted: 22:57 - 19 Jan 2007 Post subject: |
ok kool (glad i didnt )
so i should put it up 1 from the bottom (pointy end) now?
as it was 1 down from the top and now its right on the bottom 1!
thanks again! ____________________ pg |
| djneu-trix |
| Odie |
 Odie World Chat Champion
| djneu-trix |
 Posted: 19:50 - 20 Jan 2007 Post subject: ITS UP AND WORKING!!! at long last!!! |
After taking the tank of 14 times and messing about with it loads its now up and running ! did a plug chop after a 5 mile ride and its a nice tan colour!
i found out it was just the main jet and that the circlip on the pin needed to be right at the top!
thank god its moving i really cant belive i did a whole engine rebuild with just a hanes and you lot!!!!!
thanks for every ones help that helped me with jetting and the rebuild on my cylinder! i couldnt have done it with out you!!!!
Pat on the back!!!  ____________________ pg |
| bish777 |
 bish777 World Chat Champion
| djneu-trix |
| djneu-trix |
 Posted: 21:36 - 21 Jan 2007 Post subject: |
Forget changing the reeds to carbon ones. Might make a tiny difference to performance / throttle response compared to normal fibre ones, but barely enough to notice and is not likely to help this problem unless the reeds in there are damaged. If they fail to seal then you will get all sorts of problems. Easy enough to take out and check them.
On a slide carb mixture pretty much depends totally on throttle position. For a plug chop you need to be at high revs / full throttle for a while. Normally best to find a steep hill so you can do this in a lower gear without going silly speeds. Once you have held full throttle / high revs for a while pull the clutch and hit the kill switch, coasting to a halt (DO NOT let the clutch out / start the engine until you come to a halt and have checked the plug).
So, basically also try to go past 5500rpm with different amounts of throttle.
| djneu-trix |
| djneu-trix |
 Posted: 22:12 - 21 Jan 2007 Post subject: Re: JETTING??? help me please!!! |
| djneu-trix wrote: | Hi all
THANKYOU!!!!  |
as above!!!
170cc bb kit and all the malarky that came with it!!! ____________________ pg |
| djneu-trix |
 Posted: 23:18 - 21 Jan 2007 Post subject: |
PLEASE HELP ME SOMEBODY!!!!!! AAAAAAaaaaaaRRRRRRggggggGGGGGGHHHHhhhhh!!!!!  ____________________ pg |
 Posted: 23:35 - 21 Jan 2007 Post subject: |
Which jets are you using now?
Cannot remember the main jet size on the NS as standard. Suspect it is around a 110. What main jets have you got with the kit? Is there a replacement needle jet?
To be honest, if it is running safely now (and rich is safer than lean) then I would be tempted to leave it as is for now until it is run in a bit.
| djneu-trix |
The last post was made 19 years, 165 days ago. Instead of replying here, would creating a new thread be more useful? |
