powervalve question
salty21
PostPosted: 13:20 - 21 Jan 2007    Post subject: powervalve question Reply with quote
what is the purpose of having a powervalve. ie why not just have the exhaust port pemanently open?
NSR Mick
PostPosted: 14:15 - 21 Jan 2007    Post subject: Reply with quote
It's to give the bike some midrange. I'm sure Keith will be along shortly with a more technical answer.
PostPosted: 14:24 - 21 Jan 2007    Post subject: Reply with quote
Exhaust port is open all the time that it is uncovered by the piston. However at different revs the port wants to be uncovered at different times to produce best power. The power valve effectively moves the top of the exhaust port, depending on revs, to produce more power at those revs.
Just like variable valve timing on 4 stroke cars.
salty21
PostPosted: 14:44 - 21 Jan 2007    Post subject: Reply with quote
would it do any damage to leave a powervalve open all the time as mine is a bit sticky
PostPosted: 14:46 - 21 Jan 2007    Post subject: Reply with quote
No, no damage is likely to occur. Just expect stuff all low down power and a noisier exhaust. And the longer you leave it the harder it is likely to be to unstick the valve.
alains
PostPosted: 17:08 - 21 Jan 2007    Post subject: Reply with quote
when the valves are partly closed the torque is improved . it's a question of timming between fresh mixture in and burned mixture out .if you had no exhaust and no powervalve , after burning the mixture , part of the fresh mixture will be out with the burned mixture . if you stop burned mixture , fresh mixture cannot go out . so when the power is closed it blocks the burned mixture partly , the rest is blocked by the pipe and this is why the pipe is also very important . you can try to unplug you servo-motor , put manually your valves fully open and have a run . you will see the result : some problem to put the revs up between 2000 and 7500 rpm
The last post was made 19 years, 268 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.45 - MySQL Queries: 13 - Page Size: 50.21 Kb
