restriction choices
carlmalibu
PostPosted: 12:45 - 23 Jan 2007    Post subject: restriction choices Reply with quote
Hello all, after going and looking at a very nice but too expensive SV650 I think I'm going to have a look at a few thundercats. The problem is restriction on them.
I rang up local yam dealership they said they sell the FI kits, but I explained that I'd prefer a throttlestop or similar as FI hold a monopoly (151 pounds for 4 washers?), so I rang swinton bikes, rotherham. Had a chat with the owner and he said he only signs FI kits because he wants to cover his back - I explained that the police see dyno read outs as proof and he ummed and arred and said if I brought him a kit he'd fit it and dyno it, or he'd dyno a bike I'd fitted with restrictors. Then he told me that the FI sheet says "30mm" which he assumed was the gap left in the washer in the inlet manifold.
What choices do i have now?
He said there are yam standard throttle stop restrictors but he doesn't know where to pick them up from, or I could get some washers made? Would that be a viable option? Certainly cheaper than 151 + labour for fitting.
Cheers.
Shine on, you crazy diamond
CB500, woop.
Gazdaman
I did a trackday!!!
PostPosted: 12:49 - 23 Jan 2007    Post subject: Reply with quote
Find someone with any IL4, get them to scan or measure the gap in the washer.
If you go for the SV, get washers from someone with a twin.
Then get someone to cut it out of some aluminium sheet, drill the right size hole. (Shape isn't important, the F.I ones are oval to make it harder to measure/replicate.)
Fit them, dyno it, job jobbed. £50 max including dyno. If you make the washers yourself it'll be cheaper too.
Gaz
Al
PostPosted: 13:31 - 23 Jan 2007    Post subject: Reply with quote
The gap in the middle of the washers for my FZR400 is about 14mm.
If your taking the washers out after the dyno run anyway it might not hurt to have the hole in the washer a little smaller just in case.
Yamaha FZR400RR 3tj
My Instagram Thingy
carlmalibu
PostPosted: 13:32 - 23 Jan 2007    Post subject: Reply with quote
the SV was FI so I'd have had to pick up a restricted ECU.
If the hole is 30mm is that really all there is to it?
edit:
No I want to keep the restrictors in I think.
I like legality/safety.
I would be shitscared of getting caught or crashing and invalidating insurance
though when I was gonna get the SV i daydreamed about setting up a switching system between ECUs. lol
CB500, woop.
Gazdaman
I did a trackday!!!
PostPosted: 13:50 - 23 Jan 2007    Post subject: Reply with quote
Definitely do-able. Something G's mused over in the past.
You say the hole is 14mm, but what are you measuring? We need an area. If it's a proper F.I kit the hole is oval..
So is it 14mm diameter? and circular?
Gaz
Al
PostPosted: 14:02 - 23 Jan 2007    Post subject: Reply with quote
Gaz
Yep thats right,
they came with the bike. I've just looked at the paperwork for them. It's a yellow sheet with FI International printed all over it.
Device code 18
outer diameter- 38mm
the inner diameter is infact 13.5mm.
It also has a report sheet from a garage to say the bike has been tested and is under 33bhp(well was Laughing )
Yamaha FZR400RR 3tj
My Instagram Thingy
Gazdaman
I did a trackday!!!
PostPosted: 14:22 - 23 Jan 2007    Post subject: Reply with quote
3.14159 x ((13.5/2)x(13.5/2)) = 143mm squared.
So that's for an Inline 4 configuration. I'd guess you just double that for a twin.
The outside diameter of the disk may change depending on the model of bike. And the disks must sit inside the rubbers that join the carb to the barrels.
Gaz
The last post was made 19 years, 162 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 0.68 - MySQL Queries: 13 - Page Size: 53.6 Kb
