Optimate connected to the main while starting the bike
Fbyte
PostPosted: 16:39 - 23 Jan 2007    Post subject: Optimate connected to the main while starting the bike Reply with quote
Hi guys.
Due this nice weather Smile my bike has has a hard time starting on the morning even if i use it every day for commuting.
I got a Optimate charge (rigth now, charging the battery)
Maybe is a silly question ,but ... can you use the optimate to "help" the bike to start?
There are some sockets arround the parking so i was thinking that next time she doesnt want to wake up 8), maybe i can just connect the optimizer while the battery is in the bike, and try to start it.
Do you think is possible??
Jav
crazymotorbik...
PostPosted: 16:56 - 23 Jan 2007    Post subject: Reply with quote
Hey,
I've tried this a few times, and can say 100% that an optimate will not allow you any extra power to start your bike. As far as i can tell it has an inbuilt sensor which can tell if the batteries losing any charge. As soon as u press the start button the optimate stops charging and shows a fault with the battery.
However a bog standard charger, with no fancy circuitry, will give u enough juice to help start ur bike.
Cheers,
Shaun.
Fbyte
PostPosted: 17:02 - 23 Jan 2007    Post subject: Reply with quote
Neutral
Good, at least that saves me to try it. Time to get a new battery.
Thanks for the quick replay Very Happy
Jav
finpos
PostPosted: 17:09 - 23 Jan 2007    Post subject: Reply with quote
Optimate is too clever for it's own good so cuts the supply when it sees the drain on the battery. No good.
Ordinary charger might provide a 1/2 amp extra during starting, which is, frankly, pointless.
Big, sod off start-charger (70 quid minimum cost) is what you want. New Battery is a much better investment.
finpos.
Marci
PostPosted: 17:11 - 23 Jan 2007    Post subject: Reply with quote
The CB500 drains my 400a starter pack (yellow thing with torch and compressor builtin) every other use... needs a full recharge every other time...
FAB-Racing MiniMotoSidecars - Back with a vengeance - F1 Class 2011...
CBR170 engine, custom chassis - www.minimotoscene.co.uk
Fbyte
PostPosted: 17:18 - 23 Jan 2007    Post subject: Reply with quote
Just bougth a new battery, Varta YB10L like the old one, for around 25 quid online.
Hope it helps me to survive the winter Very Happy
Cheers guys.
MattEMulsion
PostPosted: 21:10 - 23 Jan 2007    Post subject: Reply with quote
An optimate is a battery conditioner, rather than a battery charger. Although it can charge up your battery it is at a very small charging rate and in terms of boost starting a flat battery it is no good whatsoever. But of course it is designed to be a booster anyway.
Yamaha YZF-R6
JonB
Afraid of Mileage
PostPosted: 20:33 - 25 Jan 2007    Post subject: Reply with quote
Just buy some jump leads and connect to another bike/car if you have one. I did this when I was getting impatient can couldn't be bothered to let the optimate charge the battery. Bike starts in 30 seconds. Thumbs Up
Dazbo666
PostPosted: 21:40 - 25 Jan 2007    Post subject: Reply with quote
I have a battery booster that I originally had for the car. I've used it a few times to jump start the bike, and it's worked just fine.
Note that it is actuallymarketed as a "booster" and not just a charger.
(I've since got myself a new battery and an Optimate specifically for the bike though Wink )
Word of the day : DILLIGAF
PostPosted: 19:41 - 26 Jan 2007    Post subject: Reply with quote
Sounds like your fuel enrichment circuit is blocked.
Robert2014
PostPosted: 13:28 - 27 Jan 2007    Post subject: Reply with quote
hi there Change the Earth Wire from the Battery to the frame put a thicker one on and that will help the battery to charge in the Winter Hope this help's
If you require a mechanic then I am your man. Bike collection and recovery service available. Don't let a monkey work on your bike, call the family run business on 07778 873 184 01505684994 https://www.rdbikes.co.uk [email protected]
The last post was made 19 years, 265 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 1.33 - MySQL Queries: 13 - Page Size: 69.65 Kb
